Trying to get old spree to run--Help!
MySpree
Post by MySpree »
i fryed the aero harness.... so i need a new one... teh harness is pretty much electrical tape
Musicman823
Post by Musicman823 »
Anyone keen on what gauge wire for the battery? 10? 12? 14? certainly not 18.
MySpree
Post by MySpree »
i think its 12
Jfunkhsr
Post by Jfunkhsr »
got the starter motor running and the engine running
bogs out around 22 or so because of the "ghetto" air cleaner i'm using. I placed a bid on a stock one from ebay and thanks for the email address for parts, i will contact him too.
Musicman823
Any definitive answer on what gauge wire the battery takes?
MySpree
Post by MySpree »
no... uhh u could check the honda spree manual on this site...
Musicman823
Yeah, I checked the manual, maybe I missed it, but I don't think it says anything about wire gauges. Noise?
Can you measure the wire that's there, or is it totally missing?
My guess? 12 or 14 gauge, thicker is always better. I'd just get the heaviest braided wire that your local shop sells (it will be 10 or 12 gauge) in a few colors (red, black, green maybe) and run that.
Musicman823
So, I ended up getting a 12 for the battery; and I figured out that the original wire was a 14. The repairs went smooth as some of the wiring had been overloaded or something, it was all melted together. I am going to test all of the electrical s*** and make sure that nothing is going to cause that to happen again. I'm getting a spark out of it though, and the starter is working as well.
Now, all I need to get is gas to the engine, and it should start. Hopefully I will have enough compression.
darat
Post by darat »
more then likely it will run... if u got compression and spark and fuel something is going to happend..
Musicman823
everything is good except I'm not getting gas out of the tank. I installed clear fuel line--that's how I know. I'm going to troubleshoot this, I'll let you guys know what happens.
