Fab Flash 7: Fabrizi 50mm Cylinder Kit (74.6MPH)
ped
Re: Fab Flash 7: Fabrizi 50mm Cylinder Kit (74.6MPH)
Post by ped »
bonesv wrote:
ped wrote:Hi wheelman. Now with the reflex it's smooth sailing. :smile:
you did everything possible for flash.
now that flash is being castrated for a good cause. lol respectfully.
you can keep the oil pump. tie it open on full, put a 92 jet in stock carb. no premix required. Have Wheelperson keep an eye on temp. I don't see any issues. I've been driving one like that for years. gas and go.
:peace:
Sorry to just jump in here, but did you imply that you are running a corsa and arrow pipe with a stock carb and oil pump, with no pre-mix? For how long? I am going by your signature also......
Hi bonesv. no not my spree. my 94 elite SR.
Polini Corsa, 9to1 gears, stock SR pipe(no washer), stock carb 92 jet, stock oil pump tide on full. 50 mph, 55 top speed downwind.
because I own another scooter I only get to put about a thousand miles a year for the last 5 years no issues or problems.
hope this helps someone.
bonesv
Post by bonesv »
Oh, with a stock pipe..... That's just a little risky for me. I run a malossi cast iron, NEW SR oil pump, and yms pipe, and still use 1.5 oz. oil added per tank.
Ped, do you have a pod filter on it? or stock airbox?
ped
Post by ped »
bonesv wrote:Oh, with a stock pipe..... That's just a little risky for me. I run a malossi cast iron, NEW SR oil pump, and yms pipe, and still use 1.5 oz. oil added per tank.
I run a stock air box with both port holes open.
I must admit occasionally I drop a ounce of oil in a tank.
Polini makes a good cylinder.
hope this helps wheelman. go with the Polini. :thumbwink:
