fuel, compression and spark......still no go?!
toboggan
Re: fuel, compression and spark......still no go?!
Post by toboggan »
hmm. well i checked the fly wheel, its on tight, i turned the engine over with an electric drill(my battery died) i got a new spark plug (bpr4hs, i had a 6 in there, figured i could go hotter. and nothing, no light, no nothing.
I put WD40 into the carb mouth... nothing.
I put WD40 down the jug, NOTHING.
I figure i'll check my reeds?!
someone else. PLEASE chime in(:
Thanks, and much appreciated!
~toboggan
scooterwerx
Post by scooterwerx »
did it run before the new cylinder and piston were installed? if so, its highly unlikely this is the problem.
Post by Kenny_McCormic »
Pull plug and crank over, should hear pop at BDC(this is the sound of a good bottom end dumping into the jug).
toboggan
Post by toboggan »
noob here. whats bdc?!
chevyguyjay
Post by chevyguyjay »
the piston is at Bottom Dead Center.
~2004 Geely Fashion~
Lunytune
Post by Lunytune »
I've had key problems with Briggs and Stratton years ago. I had forgotten about that. The refresher may help my new ventures into 2 strokers and scoots.
