Spreedio Performance ... AF16 BUILD
Re: Spreedio Performance ... AF16 BUILD
Its USPS fault
So i got my parts in ! Still needing a couple things to complete the build.
Reason why i chose the PG short because i didnt wanna cut ANY plastics on my scooter.
Stage 6 Clutch is next.
- Message_1489083295473(1).jpg (64.34 KiB) Viewed 15437 times
Finally got the motor built and in the spree. Rear tire rubs even with the shock tab from SSS.
- 20170322_143359.jpg (84.5 KiB) Viewed 15408 times
- 20170322_140736.jpg (85.21 KiB) Viewed 15408 times
- 20170322_131218.jpg (130.85 KiB) Viewed 15408 times
- Message_1490302545875.jpg (105.73 KiB) Viewed 15408 times
You can space your wheel out a hair by using a shim kit, or finding a hardware store that sells metric washers. Don't put to many shims tho, or more than one washer. You don't want to lose threads on the wheel nut.
Shimming the wheel out wont stop it from rubbing the rear fender.
SpreeorDie85
- Goped
Set up looks sweet. Very Jelly.
got it running today ! Its guzzles gas but halls *. pics coming soon
MJ is 114. runs very well. a tad rich but thats ok.
iam using 28:1 for break in like a gallon then gonna switch to 32:1.
Iam noticing that oil is coming out of the exhaust O ring. I tightened it up and oil still wants to come out.
Meloshameless
Sounds like typical PG quality...
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
- Rip_City_Spree
are you using the exhaust gasket that came with the corsa? if so Id suggest getting one of those fancy copper gaskets from G9. I wont use that oring gasket anymore. and for the price theres no reason you should. I could never get the oring to sit right and from experience the lower stud can snap the exhaust flange. check out my thread to see the damage. cant say it was due to the oring gasket but I wont take that chance again especially when the copper one brandon sells works so much better to get a better seal and it sits better.
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
polini corsa
Polini 26mm Carb
Naraku intake
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
order 3 or 5 of these https://www.scooterswapshop.com/product ... ust-gasket
get a basterd out and get ready to file the pg down a bit mine never fit right ask 1man about that.
no more driving it, start it up to test if you see oil kill it, repeat until it no longer has oil blowing out and I mean the slights bit on a tissue is too much and when your ripping 7ks plus its[the gasket] gonna blow out.[f*** yer motor]
2021 DRZ400sm
2021 DRZ400sm
The oil that's coming front the exhaust o ring.is normal cause I'm using 28:1 right now. Soon I'm going to 32:1. I'll order some gaskets. I have the contessa not the Corsa.
Thank you for your input .
running 32:1 now and no more oil.down jet to 112 temps are perfect. I really like these parts
Now for the next step. Can you further port a corsa kit? Contessa is great but im loooking for more acceleration. feels loosy goosy. haha
- R1Titan911
I got your Corsa & Arrow !
87' Spree: "Victoria's Spreecret"
78' Express:
78' Express:
Have you done any trans tuning? Clutch? Rollers? Springs?jakubman1 wrote: loooking for more acceleration.
