Spree - Carb -o- Death
- swimmingfree
Re: Spree - Carb -o- Death
gap the plug at 0.025
Thank you, I will do that when it gets light here and I can get a new plug and a gapper.
Dave
Dave
- swimmingfree
spree are simpull but a pain in the A.S.S
when you get it running wright you will have fun with it ..
ps
what color is the plug and the id number on the plug
ps
The plug is white.
I saw that yesterday.
I will check the ID # when I pull it today.
Briggs&Stratton, it's either a plugged high
Speed jet, or a bad diaphram.
Ths Spree is driving me wacko!!!
Bad plugs have been the issue many times here.
I am as dumb as they come.... New liquids, lines, and new plugs have always work well for me.
Assuming clean carb and compression.
Best of luck.
Best of luck.
'86 Spree - Gone
'86 Spree - Gone
'85 Aero 50 - Gone
'94 Elite SR - Gone
'96 Elite SR - Gone
'01 Elite S
'85 Gyro - Its Alive
'86 Spree - Gone
'86 Spree - Gone
'85 Aero 50 - Gone
'94 Elite SR - Gone
'96 Elite SR - Gone
'01 Elite S
I hope it is only a plug,
I am down to $5.00.
I am down to $5.00.
- swimmingfree
]the part that goes in the motor it shood be brown or black white means its lean and not good you have a big air leak some were ...rawhead wrote:The plug is white.
The part inside the motor is burned white like white ashes.
- swimmingfree
you need to stop playing with the carb and start looking for a air leek!!!!!
are the 2 o ring in place between the carb and the manifold???
Yes, the o-rings are in there.
Maybe crankseal? :t
Maybe crankseal? :t
- swimmingfree
do you have them in wright ??the one no the brown thing shood go to the motor ...
as for the seal on the case i don no how to tell if there bad or not ....
- swimmingfree
http://www.ebay.com/itm/Honda-Spree-NQ5 ... 33604d77c6
heres some seal if you need them form tazland001 ..
I got them right.
Have you ever done a crankseal?
- swimmingfree
yes not a big deal if you can get the fly wheel off ... did you pull the plug ??? is it white (a photo wood be nice )??? what the gap??
I took it off yesteray, it was white at the gap and
Around the gap. I am taking it off today.
Do you know which plug it takes?
How do I take the flywheel off?
Do I need a fywheel puller?
