Page 2 of 4
Posted: Thu Jan 13, 2005 12:22 pm
by noiseguy
darat wrote:well why don't u tell how to make your special pipe that gave u 9mph
If you are looking for a pipe design, PM me and we can discuss it. You have a couple of options.
Posted: Thu Jan 20, 2005 11:46 pm
by big
i saw a custom pipe at powersports of houston...texas that is
looked so cool...didnt ask how much.....any who
if you want 10 mph...do this shave 65 thousands off the head, port the intake and exhaust ports using die grinder and jet 1 to stages bigger
takes about 5 hours to do the job (grinding and reinstall with new head gasket....but you need a machine shop to grind the head down...also run a hotter plug....yea hoo
Posted: Fri Jan 21, 2005 9:57 am
by noiseguy
Have you tried these mods yourself, or did someone you know do them?
You can't take 65 thousands off a Spree head, unless you replace the piston. You'll get piston-head contact. The head has about .020" of extra material, of which you can remove some to most of and still be safe. I safely pulled .015" off mine and it's still fine.
Posted: Mon Feb 21, 2005 1:30 am
by vette76
Posted: Mon Feb 21, 2005 8:58 am
by noiseguy
There you go. Uses pre-filled (disposable) NO2 cartridges, as it should. Not sure how you're supposed to control the flow, though, I don't see any valves.
Posted: Mon Feb 21, 2005 7:39 pm
by darat
that is bad * nos but could be a little cheaper
Posted: Tue Feb 22, 2005 4:10 pm
by noiseguy
darat wrote:that is bad * nos but could be a little cheaper
$50? No, it could not be much cheaper. Check out the price of a real system that won't blow up your motor: $650. This includes an additional fuel jet so that the N2O doesn't lean out your engine and blow a ring.
http://www.speed-sports.com/motorscooters/NOS_kit.html
Posted: Tue Feb 22, 2005 5:37 pm
by vette76
that kit is not desighned for a scooter. its desighned for a car. its called a cheater system and desighned that small to be hidden. its in jegs for 300 i think.
Posted: Tue Feb 22, 2005 9:06 pm
by noiseguy
It would work for that too, but the pictured system is designed for motorcycles and scooters.
Posted: Mon Mar 21, 2005 6:40 pm
by mopedman
nos is good for you health
Posted: Mon Mar 21, 2005 9:25 pm
by vette76
what?
Posted: Tue Nov 15, 2005 11:02 pm
by wickedSpree
What is lbs shot of nos.
Posted: Tue Nov 15, 2005 11:03 pm
by wickedSpree
if you shot is to much you will blow that spree up.
Posted: Tue Jan 03, 2006 12:52 am
by ANARCHY
best thing to do is just change the motor to an elite s or dio motor
Posted: Tue Jan 03, 2006 12:55 am
by bitteraspects
wickedSpree wrote:if you shot is to much you will blow that spree up.
dont forget to post pics
