Sym dd50 build!!
Re: Sym dd50 build!!
It doesnt matter if you dont have any problems with it now, trust me, just swap it out.
If your gonna insgall new bearings and seals, you might as well install a new crank, port match the boost port, and open up the intake port. Stock intake port on dd50 block is smaller than stock af16 intake port.
Sym dd50 build!!
I'm defiantly going to port it otherwise no point to crack the crank case!!
SYM dd
50mm 82cc KABOOOOOMMM
Strengthend crank
V8 typhoon
Malossi clutch springs yellow
Datona +20% center spring
kitako type x variator
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
Got one of these on the way, with a stronger connecting rod for bbk!
Still waiting on:
75cc bbk
Crank bearings, top end bearing
Crank seals
Oil pump plug
Crank puller, bearing puller, flywheel puller,
New fan
New drive belt
It will be a new engine when I'm finished all that will remain is the crankcase!
Still waiting on:
75cc bbk
Crank seals
Oil pump plug
New fan
New drive belt
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
is that from yahoo auctions?
how much?
mini stroker?
how much?
mini stroker?
Sym dd50 build!!
It's from Taiwan and I found it on alibaba.com It's not a mini stroker it's a regular 41.4 stroke
It is about 60$us delivered, they have a stroker for about 100$ delivered but I don't know if it would match the port timing on the bbk I baught so I'm gonna go stock.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
Got that ordered and was reading a thread about a nice build by burnt toast and was wondering. I have a OKO28mm carb already, Baught it and never used it!
Would I be able to use it on this build or would it be too big?
I currently have a 21mm OKO
I'm going to port its intake and boost to match the bbk which is better!
Don't say 24mm cause I haven't got one?
Which is better?
Which is better?
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Sym dd50 build!!
Parts started arriving today!!
Fan top end bearing and crank seals.
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Is that another stock dd50 crank that you bought? You shoulda jist got a stock af16 one. Or a stock full counter. Ive had bad experiences with stock dd cranks, where the two halves loosen up and con rod falls out or the crank breaks right by the crank seal on the pulley side.
If you have the 28mm oko, it should be good already. Youre porting the block anyways, just jet it correctly and you should be safe.
Use the 21mm.Madman wrote:I have a OKO28mm carb already.
I currently have a 21mm OKO.
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Sym dd50 build!!
It's not the stock crank it's designed for tuned engines. Just the same stroke.
Ok that's 1 for 28mm
And 1for 21mm
And 1for 21mm
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- Downsouthdio
21 is reAl simple to tune.. 28 will make more power up top.. Jus a lil
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
- Downsouthdio
Sym dd50 build!!
Thats 2 for 21mm
1for 28mm
1for 28mm
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
- paulpauly7
id say 21 better for inner city traffic and easyer to tune the 28 if your a highway runner
Sym dd50 build!!
Well I drive in the city! Tokyo!! And scoots are not allowed on the highway here so that = 21mm
SYM dd
Strengthend crank
V8 typhoon
Oko28mm
CT intake
Strengthend crank
V8 typhoon
Oko28mm
CT intake
