New Elite SR
Chicago Ben
Re: New Elite SR
Post by Chicago Ben »
Wheelman-111 wrote:Greetings:
NOOOoooo! Don't mess with the graphics!!
If you want a different look, I'd swap my red ones witchoo in a heartbeat were it not for the $franklin in shipping.
I agree, don't change the look
1995 SA50P
pop pulley
50mm Ruima
8.44:1 gears
PG Typhoon
1500k spring
1000k Polini triples
M Keli clutch
28mm Keihin PWK
OKO Polished intake
uni filter
sjleto
Re: New Elite SR
Post by sjleto »
I usually agree with veedubh20, but not on this.
If you find a good AF16 block, it will cost a good bit of money. You already have a decent block. There's nothing much wrong with the 05, and plenty of mods available to make it a lusty 65cc. Mine was good for a GPS-verified 58.6 MPH in less-than-optimal conditions. I'm fairly confident it ran 60 on a couple of other occasions, just didn't have Garmin-Girl along for the ride.
Yes, an AF16 can be made much faster, but you don't have one of those. You DO have your 05 and the fun is in the modding anyway.
What did you do for gears on yours? After all these post and reading more I think I am going to have to do a big bore kit I am just wondering about gearing?
And don't worry, I have no plans of taking the stickers off and changing how it looks at all. To mint.
92 Honda Elite SR
-Ruckus Variator Mod
93 Honda Elite SR
fastplastic
Re: New Elite SR
Post by fastplastic »
there should be a write up in tech docs. or hit the search button and look for afo5 gearing.... if you ran 9.1 gears and derestrict the motor you should be able to hit pretty close to 50mph stock might not take off as quick but will still make spree look slow....
Re: New Elite SR
Red Eft Performance is selling the Malossi 7.83:1 primaries. They were super-rare two years ago. Presuming it's not too late, spend the $92, or you may not get another chance.
Yeah, they suck for take-offs and won't be much fun on 50cc power, but the Slippery Slope of Modding awaits.
tazland001
Re: New Elite SR
Post by tazland001 »
I just stumbled onto this post. d*** is that scoot clean. :*:
Taz
Re: New Elite SR
eliteguy50 wrote:Has anyone done 50 on a 92 afo5 without a bbk? i would say ruck vari with met wheel and 10.2 gears can run a solid 50mph. i dont think the stock engine has enough power to push up to 50.
Okay,....met wheel is tubeless....why is that recommended ?.......trying to understand how that will improve top speed......or if it has advantage in balancing....or if it improves tire options....or what ...:?:
Re: New Elite SR
It is irrelevant to top speed. It's because they can't figure out how to deal with inner tubes without punching holes in them.
Re: New Elite SR
The Met wheel is 2.15" wide. The Elites and Aeros are 1.85. When you mount a 90/90 to the latter, its profile ends up looking a little weird. Think "Light Bulb". Honda-san himself specifies the 2.15 for the standard 90/90s on his Met scooters. That's the correct size.
The 90/90 is also 3.18 "Tall" in profile, tire diameter 16.36") a significant-enough upgear over the 2.75. (Tire diameter 15.5')
Re: New Elite SR
Right,....thanx Wheel for the insight......so interchange works on Spree?....Elite?..... :hi:
Re: New Elite SR
Met wheel fits and works great on the SE/05 and SA/16 blocks. I think the rear Spree brake is smaller than 95mm on all the others, and the axle/spline count may be different. Even if the Met wheel hub fits, the biggest tire that (sorta) fits is a 3.00, for which the tubeless Met wheel might be a bit big.
