its a bmx old school odyssey clamp.you can use the mountain bike one too.find a 7/8 bar clamp and 7/8 stem.the bar is a fly racing bar for a ktm50 and I cut 1 1/4 in off the end of the bar to shorten it because it felt better shorter than long for me.SpyderMike wrote:what kind of handlebar clamp is that?
my 87 elite 50 s build
Re: my 87 elite 50 s build
yup basiclly a 87 in g clothing.the frame is the same as the 87 elite just different panels and disc front with a dio engine.
- SpyderMike
well i think im going to go ahead and steal your gunfighter style
it has grown on me something awful
its all good.the fly handle bars is the cheapest.about $37 like the same one I have the has the middle bar that can come off and comes with the bar pad too.check your local motorcycle store or google works too.any bmx or mountain bike stem clamp will work.make sure to find a 7/8 bar and stem clamp that way you don't have to make a shim for it.
- SpyderMike
i just got my hands on a local set of bars w/ throttle grip all controls and cables for $35 dude had them on his ruckus...got some metropolitan forks off ebay for $32 triple tree and all
and im going to machine up a stem clamp so that i can incorporate a headlight mount
still... when its done it wont be nothing compared to yours
edit...
i forgot to ask... how much knee room do those bars open up?
edit...
if your using a ruckus triple tree,its really wide.if your going to put it on your elite e its going to look a bit funny because the forks will be wide apart with a small rim and tire.if your going to use that setup on the front do a ruckus rim in the back and offset the motor mount to center the rear tire that way it look even front and back plus it will look pretty sick short and wide.
So I decided to change up the bike a bit.can't make up my mind.I dropped my 125cc stroker in it for a while but now I am putting my watercooled setup in and aftermarket rims and frontend.
did the new frontend on
R6 master conversion
Got the coolant in and the pump purged and did my heat cycles.
- martynkim
OMG I had no idea that was what you had! AWESOME
Thanks! its ok.
- martynkim
Dude you gotta give me some tips on how you painted that thing. I'm about to paint mine but nervous
thats the original paint on there.The side where the exhaust is got messed up from the previous owner when they dropped the bike.the trans side is very nice like the front.just take your time and don't forget to wet sand to get the orange peel look out.clean good before painting is also a good key to remember too.
- martynkim
I didn't read the entire thread but wasn't it pink?
