Page 9 of 22
Re: Spree Engine Swap: Honda Elite CH80 onto Spree
Posted: Thu May 30, 2013 8:34 pm
by Tyler VR
Back on the scooter, only the bottom will show once the side plastic is on.
Posted: Fri May 31, 2013 12:33 pm
by Dalrock
Tyler - how do I contact the fella you traded the Elite 80 body parts to? I need the front cover and knob which connects to the side covers.
Posted: Fri May 31, 2013 8:31 pm
by Tyler VR
Dalrock wrote:Tyler - how do I contact the fella you traded the Elite 80 body parts to? I need the front cover and knob which connects to the side covers.
I'm sorry, I don't think he ships.
Posted: Sat Jun 01, 2013 3:12 pm
by Tyler VR
I removed the carb from my spare ch80 and cleaned it up. I also installed bigger slow and main jets I got from Jetsrus.com
Runs a lot better and I got the top speed back after it was reduced because of the exhaust pipe and air filter.
Now I'm going to focus on getting everything painted.
Posted: Mon Jun 03, 2013 2:31 pm
by Tyler VR
Spent some time doing paint work, lots of sanding/prepping. Took these pics just prior to spraying.
Posted: Mon Jun 03, 2013 8:02 pm
by Kevinstonge
[quote="Tyler VR"]I removed the carb from my spare ch80 and cleaned it up. I also installed bigger slow and main jets I got from Jetsrus.com
How large did you end up going with the jets? Also do you know what the stock pilot jet size is? Thanks!
Posted: Mon Jun 03, 2013 8:42 pm
by Tyler VR
Here's where I got the jets:
http://www.jetsrus.com/a_jet_kit_scoote ... _elite.htm
TYPICAL JET SIZE:
Main Jet - 88*
Slow Jet - 40*
I went up to a 45 slow jet and got 90,92,95 main jets to try.
Posted: Mon Jun 03, 2013 10:44 pm
by Tyler VR
I had the front shield nearly done painted and it fell from my crappy hanger line. All sorts of marks/scratches in my fresh wet paint.
So I'm going to have to sand it back down and repaint.
Posted: Tue Jun 04, 2013 9:50 am
Your thoroughness is admirable. Eager to see results!
Posted: Tue Jun 04, 2013 2:38 pm
by Tyler VR
About to spray the side panels, there were a lot of scratches hiding under those stickers.
Posted: Thu Jun 06, 2013 6:03 am
by Tyler VR
On the floorboard I decided not paint the textured area because it would most likely rub off. But I did clean the area using a couple methods before I masked it off.
Posted: Thu Jun 06, 2013 10:49 pm
by Tyler VR
Painted the turn signal housings and some of the other smaller pieces too.
Posted: Fri Jun 07, 2013 8:35 pm
by Tyler VR
Here's all the painted body parts, turned out good. Planning on painting the frame this weekend.
Posted: Mon Jun 10, 2013 4:18 pm
by Tyler VR
Frame painted, I made sure to plug/mask all the threaded parts.
Posted: Mon Jun 10, 2013 8:39 pm
by Tyler VR
Forks and handle bars painted too.
