well got to take out my scooter the other day and i cant get it over 42 mph.
i am running stock muffler derestricted and stock variator and stock gears
what should i do to get the full power out of this motor?
i really want to see this scooter go 55 mph and i think with the right stuff i can get it there
its a 95 honda elite s
what do u guys think i should change on this setup?
72cc dio motor MPH question
2001 honda elite s 50cc
1995 honda elite s 72cc
Re: 72cc dio motor MPH question
credit limit on your card??
busting my knuckles on vices since
for long as i can remember
money is not a problem here
Get a aftermarket variator and some 9to1 or 8.5to1 gears. Did you rejet the carb?Rob wrote:well got to take out my scooter the other day and i cant get it over 42 mph.
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
Read Flash III Build Chronicles in Scooter Builds for what's possible with the stock carb and pipe.
A variator (mine's a Polini but Keli should perform very well too...) with 9:1 gears and only stock power was enough for 48-ish. Your BB should push that easily above 50. That ain't 55 however.
To get there I believe you'll need a pipe of some sort. I chose a V8 because it's a nice compromise between the low ceiling of the stock and the gutless low-end I've read about with full-race chamber pipes. Mine was relatively cheap at JiangWayne's a few months ago, but I've noticed the price went up about $50 since I bought mine.
I do not believe a manifold/carb is necessary to achieve 55, but an aftermarket filter and a substantial upjet is necessary. I ended up with around a 101 by the time I resolved some erroneous temp reading confusion. You may find an 88-92 will suffice if you retain the stock airbox, suitably drilled, but I believe the max performance suffers.
That said, if you plan eventually to do a heavy-breather pipe and replace the carb/manifold with something bigger, save time and money by installing 8.4s instead of 9:1s initially. Even without the carb, holding a 55 cruise speed will be easier; once up to speed you can relax the throttle and ride the torque at lower revs.
hope this video help.. http://www.youtube.com/watch?v=LZpBrYju-J4
you owe us 5 minutes.
- burnt_toast
yup, check out akped driver's setupveedubh20 wrote:hope this video help.. http://www.youtube.com/watch?v=LZpBrYju-J4
used that as a basis when building my own ministroke corsa setup
9:1 gears will be cherry for you
plus aftermarket variator
will need to change center and grab springs in clutch too
then she should boogie
projects galore
Cool !Rob wrote:money is not a problem here
