Slow Acceleration, other problems
jeffhardyrules
Post by jeffhardyrules »
Well I have no power or torque until I hit about 15mph and then it works fine(top speed of 32 mph) and if I have to turn and go 15 mph or slower the blinkers won't blink and just stay lit up. Would it be something with the piston?(because of the low power) Also it won't idle(it is either set to low or too high) I have put on about 75 miles+ since getting it to run better and I decided to check the spark plug which was a reddish brown, so I believe that is another problem. Thanks in advance, yet again.
eager_beaver
Post by eager_beaver »
try cleaning your carb. i had the same problem
jeffhardyrules
can do. while i do that I will also see if i can see through the idle something(i forgot what it is called) with a mag light to see if that is blocked.
jeffhardyrules
Actually the spark plug is fine. Under one of the links in the forum I found the color of my spark plug and it said it was "good" so that is good
deathwish
Post by deathwish »
my blinkers werent blinking either so cleaned the connections and grounds and it worked
Are you running the stock airbox, or a pod?
jeffhardyrules
Everything on my moped is stock that I am aware of.
Mormonmopedmaifa
Post by Mormonmopedmaifa »
my moped kinda does the same thing with power but a bit different . mine works totally fine but after its been runnin for like 10-20 minutes it loses almost all power in the 0-15 range and takes forever to accelerate, but once its up to speed runs great.
vette76
Post by vette76 »
sounds like compression loss.
87' spree (SOLD
12' wrx
jeffhardyrules
I am thinking of just selling the supid things then my problems will be solved.
vette76
Post by vette76 »
i was talking about mormon's problem. yours sounds like it could be a carb issue. does urs sound knida like its "missing"?(jeff)
87' spree (SOLD
12' wrx
jeffhardyrules
ummm it sounds weak and crappy untill it kicks in at 13(or so) then she sound pretty good exept for a minor rattling noise and she screams full thottle(i think it sounds cool though, when i give it full throttle)
vette76
Post by vette76 »
make sure the coil boot it tight/no corossion
87' spree (SOLD
12' wrx
Mormonmopedmaifa
well i dont know if its compression or what cause it still revvs pretty good it just doesnt go (it revvs a litle lower than normal but not substansially).i think it may be a transmission slippage problem.
vette76
Post by vette76 »
compression would still allow it to go the same speed, just lack power when warm. is it hard to start again when hot?if so its compression.
if not then it could be belt/clutch.
belt could be expanding/slipping
clutch could be fading (like brakes can when hot)
87' spree (SOLD
12' wrx
