So I did some research about my bike vibrating like crazy, and I found info on cleaning the clutch assembly. Would someone elaborate how, and what else I should look at doing like changing my final drive oil?
I have an 88 elite sa50 with 8001 miles and she runs smooth until she slips...
vibration...
Burgleflickle
- BMX
vibration...
"This whole thing is a travesty and a sham and a mockery! It's a traveshamockery!"
"No making up words sir."
"Burgleflickle!"
"Burgleflickle!"
88 Elite vibration
I have an '88 50cc Elite with a vibration at low speeds that I can feel through the handlebars, seat and floor. Does that sound like yours? Did you ever get a response to your question/problem?
There is no such thing as a unique idea, just better uses of the old ones.
you can eliminate 2 things real fast, with the front brake on push the scoot forward & back any play means the steering stem race bearings are shot, next with the scoot on the center stand move the rear wheel back & fourth any more than 1/4 in play and the motor mounts are shot= a b**** to replace, the last thing would be a bad crank bearing which will cause the engine to vibrate & lose power
