No idle and gas in vaccum tube .
smitty
Post by smitty »
Hey guys and or gals I'm still working on 86 spree that starts good but wont' idle ..plus gas is coming into the vac tube between carb and fuel valve...I took someones advice and removed the choke and put my finger over the opening and the motor would idle down but still had gas in vac. tube...so I'm guessing that my bystarter is no good but what is causing the gas to be in vac tube. :roll:
ferchja
Post by ferchja »
Broken diaphram on the fuel valve. Get a used one and or new. The fuel is getting past the diapram and getting sucked into the intake down the vacuum.
Bystarter has nothing to do with the vacuum line to open the fuel valve.
Jeremy Ferch
1985 Spree (NQ50) - Mid restoration
burnt_toast
Post by burnt_toast »
ferchja wrote:Broken diaphram on the fuel valve. Get a used one and or new. The fuel is getting past the diapram and getting sucked into the intake down the vacuum.
werd. sounds like a proken diaphram to me. New one at Honda dealer is about $35
projects galore :nerd:
smitty
gas in vac tube
Post by smitty »
Thanks --and i just bought this used one from Paul Richardson in Mich. who is trying to sell his business and he said it was fine!!!Waited a month to get it at that... :evil:
Check the valve operation per the manual to determine if it's really bad. If it is, write Paul back and tell him what's going on. Paul has been an honest dealer in the past, and I'm sure he'll make it right.
smitty
re diapharm
Post by smitty »
just bought a new petcock and installed it and still get gas back in vac tube. plus the rascal still won't idle...ready to get new carg. Smitty;
ferchja
Post by ferchja »
Do you have the tubes hooked up right? Or are you sure you know what the vacuum tube is? There is no way gas can get into the vacuum tube if the fuel valve is working properly.
Jeremy Ferch
