Rear cam stuck?
shortcal
Rear cam stuck?
Post by shortcal »
I went to change my rear brake since it wasnt grabbing well so i got the wheel off but noticed the cam was always was always slightly twisted causing the break to be slightly separated. I tried taking the adjusting nut off but it stayed in that position. Is this a hard fix? I would like a correctly functioning rear brake once I get my performance parts.
2001 Honda Elite
ANDREW
Post by ANDREW »
yes it is easy to fix just take the rear brake assembly off then spray WD 40
on it and let it sit for an hour and then turn the cam by hand to free it up
that should fix it and dont forget to clean the wd 40 off of it before putting it back together because it will reck your brake pads.
