Speed Pulley
gobucks
Speed Pulley
Post by gobucks »
how much top speed increase can i expect from a speed pulley?
Dac
Post by Dac »
some people say like 40-45 with pulley allone.
Some people even say it helps them get to speed faster. :?
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
aloha
Post by aloha »
[quote="Dac"]some people say like 40-45 with pulley allone. quote]
If it was only that easy and inexpensive. Spend $50 for a High Speed pulley and gain 10 MPH :? . Hey DAC, I know you were looking for panels on FH. Just a heads up, got some on Ebay.
monkeywrench
Post by monkeywrench »
my red elite does about 43to47 mph with just the pulley
here kitty kitty kitty
http://www.youtube.com/warmonkey80
Elite1998
Post by Elite1998 »
Dac wrote:some people say like 40-45 with pulley alone.
Thats what I got with the "Keli" variator($50 value) and even going against the wind I can keep the speed up to 35-37mph compared to 30-33.
And actually it seems the acceleration is slightly faster than the stock one..very slight increase..it is a little more noticeable from 30-35 and then it slowly goes up from there to 40-45mph. Just so you know, I believe I have 9g rollers.
Putting thought into it it should give you a 5, maybe a 7 mph increase. The time I hit 45, I had the wind to my side and probably my back too..which with the stock pulley I could hit 40.
Honda Elite SA50-S
Stock motor, 9:1 gears, Kelli High speed pulley=a top speed of ?? Maxed the speedo out if that counts..average 45 mph
average 85 mpg
aloha
Post by aloha »
Elite1998 wrote:Thats what I got with the "Keli" variator($50 value) and even going against the wind I can keep the speed up to 35-37mph compared to 30-33.too.
This I can believe.
monkeywrench wrote:my red elite does about 43to47 mph with just the pulley
43-47 MPH with just pulley, B.S.
chevyguyjay
Post by chevyguyjay »
i agree with aloha. :o
~2004 Geely Fashion~
monkeywrench
here is your b.s. ha ha ha ha ha ha bla bla bla. and here is the kicker my high speed pulley came off of a peace of sh1t t5 chinese scooter.
my scooter is a sr elite anyway so those speeds should be preaty common with just a pulley. ah so hu if you want to b.s. me some more than f.off
aloha
Post by aloha »
I still say B.S. No way you can hit 43-47 with just a pulley mod. And so what if it's an SR, that's basically a derestricted S. It also seems you are not the original owner so you don't know for sure the gears were not replaced and you were not informed. Pulley mod will get moped up to speed faster and does not make you bike gain MPH's. Gears will give you more top end. If you only weigh 90 LBS., was going down a steep hill and had a gust of wind behind you, then maybe.
***END OF THREAD, STFU!!!***
monkeywrench
sorry dude but i can turn the fxxxing clutch 12 times for the wheel to turn once and yes there is a dif in the s and sr even if u have both of them deristricted all the way . the carb on a s has a #68 main jet sr has a#78
and i put the fxxxing thing together. so i know whats in it and what isnt.
my results is what it is so go b.s. yourself
now its the end of thread and u stfub
sorry to everybody else thats has to read this sh1t just pointed toward aloha
aloha
Post by aloha »
:roll: OOOOhhhhhh you put it together. Whoopty * doo. So you think you can build motors? By all the NOOB questions you asking in your previous threads, I think not!!! It's o.k. to ask questions, but when you think you know it all, that's time for you to get a reality check b****. If you know so much about building mopeds, you would see how stupid it is for you to claim that type of speeds. HAVE A NICE DAY AND KEEP TELLING YOURSELF THAT YOU HIT THAT WITH A CHINESE H.S. PULLEY. YOU'RE ONLY FOOLING YOURSELF AND THE OTHER NOOBS!!!
OH YEAH, GTFO AND STFU WITH THAT s***!!!
monkeywrench
it is what it is u see my resaults so shut the fuxx up mister fuxxing scooter scientist. u aint nothin anyway and quit talking s*** with your dxxx flaps ya bxtch.
ya when i first got the elite i didnt know what all you could do to them.
to tell you the truth i just stumbled across this forum and started asking questions after i started tearing in to these thing i learned a big dill about them. then i started to build one with aftermarket parts and then i found another one that was just a frame half the motor and back wheel. after i putt that one together i putt the chinese pully on it and found good resuilts.
aloha
Post by aloha »
So you show a pic of your speedo :roll: . That doesn't mean that you're not * what you run in it. I can show you a pic of my speedo burried and say it's stock. b**** PLEASE!!! When you learn more about motors and what it takes to gain speed, then you can talk. You have no * clue what you are talking about. You want proof? Look at your other posts in the other threads.
monkeywrench
ha i have another elite that has 7/1 gears 72cc kit 1500rpm shift spring and high speed kelly pully and 24mm carb with double reed valves and a pg long pipe so you aint telling me nothing. ill smoke your * anyday
aloha
Post by aloha »
Anybody MONKEY can slap on parts. It's all about the tuning.
Locked
