Just purchased this 85 Honda Spree. Charged the battery, cleaned the carb several times and checked it all over. It will now start and run but has no power and is hard to keep running. It will idle for a short time, maybe a couple minutes. I can keep it running with good power by spraying carb cleaner in the air cleaner side of the carb. Seems like a lack of fuel. I check the petcock and it is giving a good amount of fuel. Please help.
Thank You
Actually, I think it's running too lean. Do you have an air filter in the airbox? Spraying in carb cleaner should cause it to sputter out and die, not run better.
yes, As I said I think it is a lack of fuel (too lean). I was just pointing out that the petcock is working. Yes it does have a good air cleaner in it. Any idea's?
cleaned out the muffler and actually put a differnt good muffler on and made NO difference. No holes in the air box and there is a good air filter in it. Any other idea's???? Please help.
