happyman
Posts: 144 Joined: Sat Feb 09, 2008 11:57 pm
Post
by happyman » Tue Feb 19, 2008 5:40 pm
Is the 1997 Elite the same scooter as the 2000 Elite ?
Thanks,
Happy
Posts: 4957 Joined: Sun Apr 16, 2006 11:51 am
Post
by Kenny_McCormic » Tue Feb 19, 2008 5:56 pm
Im pretty sure 94-01 are all the same internally.
burnt_toast
Posts: 3469 Joined: Sat Jul 31, 2004 8:00 pm
Post
by burnt_toast » Tue Feb 19, 2008 6:41 pm
yes indeedy
projects galore
Dac
Posts: 3340 Joined: Sat May 05, 2007 5:58 pm
Post
by Dac » Tue Feb 19, 2008 7:55 pm
burnt_toast wrote: yes indeedy
...feed the needy
[i got a few friends that say it all the time. Dont ask...]
1996--------Honda Elite S-
1991--------Tomos Targa-
And a Bunch of other bikes.
happyman
Post
by happyman » Tue Feb 19, 2008 10:20 pm
Kenny_McCormic wrote: Im pretty sure 94-01 are all the same internally.
Thanks to all?? do all the transmission part interchange too?
Happy
Dac
Post
by Dac » Tue Feb 19, 2008 10:55 pm
all honda elites 50's...
94-01
are the same bike part for part. The only and only difference is the some bikes are restricted and some are not. All parts are interchangeable.
happyman
Post
by happyman » Wed Feb 20, 2008 12:01 am
Dac wrote: all honda elites 50's...
94-01
once again thanks all
Happy
stillspeeding
Posts: 279 Joined: Fri May 04, 2007 3:50 am
Post
by stillspeeding » Thu Feb 21, 2008 1:54 am
There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.
happyman
Post
by happyman » Mon Feb 25, 2008 6:31 pm
stillspeeding wrote: There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.
someone told me the part of the frive is double bearing instead of 1 was 2 till 98 i guess
veedubh20
Posts: 1666 Joined: Sat Dec 31, 2005 7:00 pm
Post
by veedubh20 » Tue Feb 26, 2008 2:18 am
happyman wrote: stillspeeding wrote: There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.
I told you on the other forum...
outer gear over only.
87,88-93,94-98 2 bearing cover & 1 bearing on 99-01 only...
happyman
Post
by happyman » Tue Feb 26, 2008 10:43 am
veedubh20 wrote: happyman wrote: stillspeeding wrote: There was a washer eliminated in the final drive gear either in 97-98 everything else is the same.
that was nice of you . now others also know it... its great!
Happy
uksailmaker
Posts: 10 Joined: Sun Sep 23, 2007 12:04 pm
Post
by uksailmaker » Wed Feb 27, 2008 5:56 pm
94-01
There are some small differences. I bought a 96 fork for my 98 and the fork fit except it is missing the bearings.
the 98 bearings will not fit over the tube the 96 tube is a hair bigger in diameter.
WHERE DO I GET THE BEARINGS FOR THE 96 FORKS
AND WHERE IS THE BEST PLACE TO BUY A BATTERY FOR A ELITE 150 12v-9 which is bigger than the 50 battery I bought at Walmart.
