Painting a Spree
Painting a Spree
Has anyone done this? What paint did they use and what works the best? Also, how do you remove the front fender?
- Streetglow
- Goped
HuskieMobileMan
I repainted my Aero with Rustoleum. Best paint for everything. Use a very fine sandpaper to take the shine off of the plastic and then paint it with 3+ very light coats a few minutes apart each other. The only problem is that if you come back to paint it later, it may bubble on you.
'87 Elite SE50 w/65cc Polini Kit
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
'84 Aero NH125
'84 Aero NH80
'05 Kymco ZX50
xela_p2004
krylon is hard to make stick, when i paint i sand everything finely then i use self etching automotive primer, then i use automotive paint over it, then i use duplicolor clear on it , i put on as many layers of primer as i need to sand down all the imperfections usually around 5, i don't like any scratches or dips in my paint, then i put about 3 layers of paint down, then i put 6 layers of clear coat followed by sanding with a fine grit just to scuff up the clear and fix the imperfections not breaking through the clear then i put one last coat of clear and then im done with a little polishing.
I used Fusion paint with a professional plastic paint prep from an auto paint shop and had very good luck with it... paint has held up two years, even on the footpad.Streetglow wrote:I've tried krylon fusion on plastic pieces before and I highly recommend AGAINST it. I'd try what MySpree listed before touching fusion again.
HuskieMobileMan
- Farfignugin
If you're not going to prep you're wasting your time with a rattlecan or a spray gun, though your point is taken. However, most people don't have access (or can't afford) a compressor and spray equipment... what then? Spree are hardly worth getting painted professionally, and brushing the paint on would really look like crap.MySpree wrote:like i said, its hard to make stick, i made it stick ONCE and it still is on there and is not even cracked. but it was alot of prep, more pain then i want to use rattlecans, if im going to prep that much, i use my spray gun.
Aluminum requires it's own special paint, with an etcher as I recall...
There is a pic of mine on this page
http://www.zumaforums.net/viewtopic.php?t=8
Its some cheap automotive touch up paint. Gunmetal grey.
