starting problem help please
cannon3731
Post by cannon3731 »
I have a 85 spree that i rebuilt the motor and it starts and runs great. After sitting for 2 or 3 days it wont start unless i put gas down the plug hole or put my hand over the back of the carb. Once i get it running it starts great even after setting for 5 or 6 hours. I have cleaned the carb 3 times and replaced the by starter and this didnt help. Any ideas would be great
Thanks
Re: starting problem help please
Post by Kenny_McCormic »
cannon3731 wrote: After sitting for 2 or 3 days it wont start unless i put gas down the plug hole or put my hand over the back of the carb. Once i get it running it starts great even after setting for 5 or 6 hours.
does the bike have the air cleaner on it normally? it sounds like your petcock might be bad. clean the petcock
chevyguyjay
Post by chevyguyjay »
sounds like to me u need to re-soak your air filter in some oil. :wink:
cannon3731
It does have the air cleaner on it normally. It a brand new air filter and the filter has oil on it. I have cleaned the petcock and it works fine. I have put a vac on it and gas comes out.
Thanks
test ur bystarter
cannon3731
I have tested the bystarter and its fine. Any ideas
Thanks
