Spreedio Performance ... AF16 BUILD
- Xxbeejay45xx
Re: Spreedio Performance ... AF16 BUILD
Nice job it's coming along
95 Elite SR af16e
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
Polini vari, clutch, springs
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Front and Rear disc brakes
Dio Live headset
Stretch and fatty rear wheel
72cc Polini Corsa
28 Oko Carb 58/144
Ported intake
ZX Trans
5.5 rollers
Malossi crank , CDI
Genuine Arrow pipe
Dio Live headset
112 Is way to lean my plug is white af!
Temps were 340.
Temps were 340.
Cleaned my stage 6 filter 1 time and the glue is already starting to come undone. I used FAB1.
- 20170402_191429.jpg (87.15 KiB) Viewed 13029 times
I've been figuring out that stage6 quality is crap.
I do also have the polini filter buuut. should i leave the plastic cone on it? My rear tire kicks up all the dirt on the tage 6 filter
Yah leave the guard on it or use the oem box. My foam filter is a liability in the rain.
Anyone got port degrees for the contessa?
Is that even the term ?
I ran that Polini filter, briefly, on one of the Flashes. maybe the 90cc mini-stroker. I can tell you that snapping that rain cover over the foam filter caused a hopelessly rich situation - it barely ran above idle - because the limited area of the sum of the holes in the plastic cover increased the negative pressure so significantly. If you must run it, be aware of its airflow-limiting effect and be prepared to downjet by 3 or more sizes. I personally think it strangles anything bigger than 50ccs. There was nothing wrong with the Polini filter itself, but the plastic rain cover stifles airflow. A lot.
I wish there was a happy medium w aftermarket filters. It seems that they either flow too much or not at all. I've been looking at these remote mount airboxes for go carts lately. Ugly but look interesting.
Check this thing out. Looks like an air filter from a ww2 tank.
http://m.ebay.com/itm/44mm-Air-Filter-f ... ING_ACTIVE
So my top speed was 55. Sounds like it's winding out topped out
- R1Titan911
Thats sounds good for a Contessa? Swap rollers?
I have a Corsa that can fix that top speed
87' Spree: "Victoria's Spreecret"
78' Express:
78' Express:
New top speed 61mph with 8 gram rollers. Pretty boggy though
Does anyone know the compression ratio of the corsA?
I'm bout to get the corsA ported !!!!
Does anybody know the compression ratio for the corsA kit ?
