AF16 Powered "Victoria's Spreecret"
Meloshameless
Re: AF16 Powered "Victoria's Spreecret"
Na, hes prob got em in stock.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
- R1Titan911
Put in the 116 in the other night and temps rose to 360-370. I put back in the 118 this morning and she hits about 330-360 on WOT pulls. I assume still on the break-in heat... Smoked a little more than normal at idle but again i still assume this is because of the 45 Pilot. (G9 WHERE YOU AT!) At least when i let off the throttle she goes back under 300 quick. Didn't change my weights yet but getting to 60 no problemo. Like others have preached, she is frightening when over 50 mph... I want to hold WOT but d*** its sketchy lol! Brakes work as intended but hope to never face and emergency situation lol! Just rode to the gym and back this morning and think i woke up the entire community haha!
87' Spree: "Victoria's Spreecret"
78' Express:
78' Express:
hi R1. Like the looks. real niceR1Titan911 wrote:Yes I am running 32:1 premix on premium. I am on my 3rd tank.
At the WaWa on the way home before she died lol! A Yammy R1 pulled up next to me at a light and said "What the f*ck is that?" ROFL!
I trimmed my taillight plastics but not enough and was rubbing. AND the exhaust melted one side up to the turn signal lens... So i took off what i had to, but still have the tag on there with the brake light lol! Just an excuse to buy more stuff and figure out how i can run some LED set when the plastics are on.
I like to keep my temps around 350 or so, but never do. lol.
I feel fine going 60-65mph. But over 70mph
Keep up the nice work.
I feel ya bro haha. It's fun going scary fast but trouble comes in a hurry in 10" wheels. Our drum brakes seem to work great for these wheels, as I can attest since I locked up my front and dropped mine like a noob haha.R1Titan911 wrote:she is frightening when over 50 mph... I want to hold WOT but d*** its sketchy lol! Brakes work as intended but hope to never face and emergency situation lol!
I think me n you arnt helping ourselves w the wide wheels and skinny tires - it creates a flatter tread profile, and I think that maybe the skinnier wheels give a rounder tread profile and more of a gyro-like effect on balance. My brother swears the big balloon tires on 10" wheels on the zuma makes it a handful on the street over bumps, and I agree.
- R1Titan911
I am not to worried about cornering. All pretty much straight pulls where i live lol. Yes at 60 its very sketchy... Like i need disc brakes but still shouldn't be doing 60 on this thing lol. Remember i'm a big boy on such a little bike. I like it and it is very fun but really think i should be on something else haha! Super fun build and just have a few odds and ends to work out.
78' Express:
78' Express:
- R1Titan911
ALL TIME HIGH! 64 MPH SUCKAS!
Switched to 5G rollers and of course slower off the line but still pulls hard from 15-64! Actually popped some wheelies but took a little pulling up on my part lol.
Still on 45/118 jets and broke down again with the same symptoms I had before thinking I was out of gas... But I had a full tank this time.
Found out it was my cheapo fuel filter from Ace Hardware wasn't flowing. It was clear and I couldn't see any debris. I swapped it out with a spare Ruck filter I had and BRAAP!
Temps still climbing to around 370ish on long WOT pulls... Again, only about 5 tanks of fuel ran through (not gauging mile per tank as I just fill up every time I pull in the garage to make sure I don't run out lol). Assume I am still in the break in heat zone?
78' Express:
78' Express:
I went down goin straight haha. I just grabbed too much front brake and it washed out from under me, hit some gravel or something. Fairly embarassing.R1Titan911 wrote:I am not to worried about cornering. All pretty much straight pulls where i live lol.
64mph! That's pretty good man.
- R1Titan911
Got my cheapo Ebay light in
Just have to figure out wiring myself as it didn't come with a diagram of what wire is what lol!
Ill mock up a bracket and figure out the flasher deal later. Any suggestions on a cheap LED flasher relay I can use in place of my 3-pin stocker?
78' Express:
78' Express:
Leds dont get brighter as you hit the break unless you wire in a resitor. My breaks are on or off as of my led im just too lazy to wire the resitor into the line.
2021 DRZ400sm
2021 DRZ400sm
I have that same light on my aero. It has 2 stage leds for the brake/tail, and amber ones for turns, should also have some white ones for the plate. Nice light, but mine lost some leds fairly quickly.
You can wire some resistors in-line to make em flash like normal. If you need help finding some pm me.
- R1Titan911
Thanks! I think i seen some on ebay but was skeptical... Got a link on what you have bought and are using?
So still getting a little hot on the WOT pulls like i said earlier. Got my pilots in and G9 is telling me i should be around 36-40/106-110 on my jets. He told me to check compression and i have 130psi which seems to be good for the Corsa. We now suspect leakage but i have done the propane check and will move on to a pressure test worse case... But first please review this image and tell me if i need to cap this nipple i discovered this morning?
Dont mind the fuel filter location as I put it there trouble shooting the last filter
78' Express:
78' Express:
- R1Titan911
Found the leak... Missed capping a nipple on the side of the carb towards the bike
Still don't know what that one is for in my pic above but i blew threw it and does not go to the internals from what i can tell.
So, went with a 40-108 jet wombo and she sputtered at WOT. Not much but noticeable.
Went to 40/110 and no sputters. Temps averaging 270-300 ish? Only could buck her to 50 mph a few times between lights. Ill read the plug and do some longer runs this weekend. Thanks G9!
78' Express:
78' Express:
- R1Titan911
Started up today to warm it up and had probs staying running. Usually once its at about 100* it would stay on with the 45 pilot. Not with the 40 i may try dropping the clip a notch and see if that solves it.
78' Express:
78' Express:
Maybe go up on the pilot since you were lean up top before. If the pilot is lean it effects the whole range.
I think that extra nipple in the pic is for adding a powerjet, but not sure.
