Honda Aero nb50 to nh125 Swap Project
Re: Honda Aero nb50 to nh125 Swap Project
Tyler VR wrote:I've seen pics online of other people doing swaps, they lay 2 inch masking tape on the floor to see alignment between the front a rear wheel. Which isn't a bad idea but it's still just eyeballing alignment off a reference point.
I imagine tape is fine when straight...but believe I would lay down a chalk-line first... :urban:
Tyler VR
Post by Tyler VR »
Bought a spare set of piston rings off ebay, these are no longer available new from honda. I hope this nh125 doesn't actually need them, but I might freshen up the engine someday.
Tyler VR
Post by Tyler VR »
Doing the final engine alignent to the frame.
Tyler VR
Post by Tyler VR »
Making sure the engine sits level.
Tyler VR
Post by Tyler VR »
Got the mount tack welded in place at a few points, will have to take it off to fully weld. Going to add a couple pieces of steel and make a bump stop from the mount to the frame.
Tyler VR
Post by Tyler VR »
My bump stop setup, found a rubber wheel for a dolly and shaved it down to fit inside the frame. Thinking about adding another dampener mount off to the side like a stock a nh125.
Tyler VR
Post by Tyler VR »
When welding the rubber dampeners inside the mount got burnt up, so I'll be replacing those.
MrJumps
Post by MrJumps »
Dont breath that smoke in lol
2021 DRZ400sm :worship:
Tyler VR
Post by Tyler VR »
MrJumps wrote:Dont breath that smoke in lol
Had to let the garage air out after welding on it, smelled pretty bad.
Tyler VR
Post by Tyler VR »
About to weld on this plate to the frame, then the shock mount on top the plate.
Tyler VR
Post by Tyler VR »
Aligning the shock mount before welding.
Tyler VR
Post by Tyler VR »
Relocated the center stand forward.
Tyler VR
Post by Tyler VR »
The aero now stands on it's own with the 125. Still need to finish up a few things, replace the mount bushings, a little grinding and painting.
Meatball
Post by Meatball »
I need to do the same thing for my center stand. Is it possible to post up some shots of the other side and maybe under? I want to see the bracket idea you went with and where you mounted to on the frame. Hows the tire clearance when in the "up" position?
Tyler VR
Post by Tyler VR »
Meatball wrote:I need to do the same thing for my center stand. Is it possible to post up some shots of the other side and maybe under? I want to see the bracket idea you went with and where you mounted to on the frame. Hows the tire clearance when in the "up" position?
The center stand I setup is pretty much just a kickstand now, it can lean a little bit to each side but the tire doesn't come off the ground. It's just a couple inches of angle steel welded to the corner of the frame with a hole drilled into each side for the pin. I didn't want it to hang too low under the frame, I thought about extending the legs of the stand itself. Also had to make a spring hanger mount, which is just a bolt I welded to the frame.
