New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
1man8scoots
Re: New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
If you get the cylinder before I leave town and want some port work done let me know. It'd save shipping out there. I need some parts coated so trade work if you're up for it
Hppowdercoatings
Sounds Good. I will Text you as soon as it gets here..1man8scoots wrote:If you get the cylinder before I leave town and want some port work done let me know. It'd save shipping out there. I need some parts coated so trade work if you're up for it
2001 Elite 72cc...http://www.hondaspree.net/phpBB3/viewto ... =4&t=31369
1984 Spree "Little Evil" 125cc AF16.. http://www.hondaspree.net/phpBB3/viewto ... 16&t=31569
Hppowdercoatings
Project "Little Evil H2O" started.. Just got the Taida 52.6mm Cyl back from 1Man after his magical port work..
URL=http://s52.photobucket.com/user/RNMHRD/ ... .jpeg.html]
[/URL]
[/URL]
You must have balls larger then the spree itself. Goood luck on that crazy thang.
2021 DRZ400sm
2021 DRZ400sm
Hppowdercoatings
Better drill a solid slick onto that back wheel ;P
2021 DRZ400sm
2021 DRZ400sm
Yeah the unported Corsa feels insane on my spree, I can't imagine what this setup will be like
84 Honda Spree... The plastic at least.
Excuse my language but that is f***ing stupid. But I love it and I want it. Can't wait to see it done.
2021 DRZ400sm
2021 DRZ400sm
Meloshameless
If you even breathe on that throttle , tires coming up and panties going down.
2000 Honda SR (purple swurp)
corsa
naruku
polini vari 5.5 gram
zx trans
Yasuni C16
corsa
naruku
zx trans
Yasuni C16
Hppowdercoatings
Hppowdercoatings
Got the Rpm 9-Spoke Front wheel Powder coated & Tire mounted..
FYI I'm still looking for a Rear Rpm 9-spoke wheel for Dio?????
Hppowdercoatings
1man8scoots
Neat I cat wait to hear how you like that cylinder. I have to run my lc set up soon too.
Peteyparado
I've almost got the same set up.. Wonder what your main jet size an slow jet?? Are u running a 30mm carb..
86 aero af16 swap. 121cc water cool.
Polini 30mm carb
Naraku mani
Scorpion stroker pipe
Stage6 CDI
5gram rollers
Keli high speed Variator
6.1 gears
94mph
Polini 30mm carb
Naraku mani
Stage6 CDI
5gram rollers
6.1 gears
94mph
Hppowdercoatings
Actually I'm running a New Polini 32mm Carb..Peteyparado wrote:I've almost got the same set up.. Wonder what your main jet size an slow jet?? Are u running a 30mm carb..
I will check on the Jetting and Post...
