01 Honda Elite- ZX headset swap, disk brake, DIO FUN
hothatch85
Re: Too many build threads- 01 Honda Elite
Post by hothatch85 »
New ensure racing wheels have arrived. Very light wheels. And are a pretty close match to the factory Honda purple :)
Gearhart
Post by Gearhart »
was all those things bolt on with the metropolitan spree?? I am thinking about adding a front disk to my spree and there is a local guy parting a metropolitan. There is no disc brake kits for metro's only for ruckus's. Did all that stuff bolt right on or was there some modification?
hothatch85
Gearhart wrote:was all those things bolt on with the metropolitan spree?? I am thinking about adding a front disk to my spree and there is a local guy parting a metropolitan. There is no disc brake kits for metro's only for ruckus's. Did all that stuff bolt right on or was there some modification?
Yes everything bolted up everything is just a little tighter since the metro tree is narrower. The ruckus and metropolitan are essentially the same bike minus the rear frame.
benji
Post by benji »
I'd love to see some pics of that install. I'm gonna try the same thing on my aero 50
hothatch85
benji wrote:I'd love to see some pics of that install. I'm gonna try the same thing on my aero 50
my parts come in today from partzilla so we will be doing the front end swap tonight, ill be following bones thread using the zx headset and handlebars
benji
Post by benji »
When you do it, if you could measure how long your fork tube is on your frame that would help even more, that way I can make sure my stock frame fork tube is the same length as yours.
hothatch85
I forgot to measure the tube I was too excited, got the frame cut and welded and mocked up the headset, it all fits! I took a few pics but got cut short due to a super bowl party. I'll snap some more later tonight or tomorrow but it's done!
As you can see, the frame neck is too long for the met tree
I cut as close to the weld as I could get on the ignition holder deal
Pre weld, I didn't take any off the top. Just one cut and weld, easy. You will need an elite lower bearing race to press onto the metro tree and new bearings top and bottom
hothatch85
Moved it in the house and tossed on the forks and wheels just to check it out. Ride height looks killerrrrrrr
MrJumps
Post by MrJumps »
If I took my ride inside I would be dead on the spot.
2021 DRZ400sm :worship:
hothatch85
Bonus of owning your own house, you make the rules. :)
bonesv
Post by bonesv »
That's looking pretty sweet!!! :geekdance: Nice work so far...... :thumbwink:
hothatch85
Next on the list is to repin the harness plugs so everything is 100% plug and play. I threw the headset on as well as the front cowl to get a a full look at it. I love it.
Rip_City_Spree
Post by Rip_City_Spree »
Looking great
01 Elite SR
polini corsa
Polini 26mm Carb
Naraku intake
Naraku sport variator
Currently 5g rollers
zx trans
Arrow
RIP CITY
RIP NO MERCY KERSEY
hothatch85
Got the dio headset repinned to the elite plugs. Very easy the only difference is one wire. I also shot a pic of the welded up stem. Super easy swap just a lot of money in parts to do it
Waiting on a speed gear setup so I can actually use my gauge cluster with these fancy wheels. Then it all goes together
benji
Post by benji »
You think it's easier to shorten the head tube or lengthen the fork tube?
