New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
Re: New Spree Build..AKA.."Little Evil"..125cc Hard Tail...
Need to move the top shock mount. Reason why left fan cooling shroud off.
Blow up the motor
Hehe
Blow up the motor
Hehe
Very nice work
I like it.
1man8scoots
61 with an official living down the street even, nice.
Hppowdercoatings
Took her out for little spin tonight to test out the new Carb & Intake.. Still really Fat. But I'm waiting on some more jets and Big Stroker Scopion pipe to install...
Top speed & Max RPM was from Dead Stop to about 450-ft..
2001 Elite 72cc...http://www.hondaspree.net/phpBB3/viewto ... =4&t=31369
1984 Spree "Little Evil" 125cc AF16.. http://www.hondaspree.net/phpBB3/viewto ... 16&t=31569
Sounds sweet! HP. Looks SWEET TOO
Hppowdercoatings
Got the Big Scorp Coated & installed today & started some Tuning..
Hppowdercoatings
- Downsouthdio
I can tell that thing was moving!!
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Sorry if I missed it, but what is that pipe you have installed in the video?
Also , is stretching the rear required when installing a Af16 on a spree? Or will it fit at standard length? Just wondering because they always seem to be stretched a little bit.
~UNDER CONSTRUCTiON~
Hppowdercoatings
johnny248 wrote:Sorry if I missed it, but what is that pipe you have installed in the video?
I'm running a 120cc Big Scorpion Stroker pipe.
Stretching not Required, but the stock AF16 mount is longer then stock spree mount. So if you wanted to build a stock wheelbase Af16 Spree you would have to cut down the af16 mount.
That spree has Power!
Hppowdercoatings
Yeah I was around 65 mph passing the white Car... Waiting on my order from Jetsrus to get here so I can finally make some Top speed Runs...Downsouthdio wrote:I can tell that thing was moving!!
- Downsouthdio
Nice man..hey,are you running heavy weights with that pipe?i blew up 3 fans while trying to get my stroker right with that exact pipe...literally shredded them to pieces.i always ran the light weights with that pipe.they might have been to light lol
Honda super dio
Corsa
26mm
Sparrow
Corsa
26mm
Sparrow
Hppowdercoatings
I'm running 36-gram Total right now in Polini Variator. Mallosi 3G clutch , Polini Blue center spring & Polini Green clutch springs, adjusted To Grab about 7000 rpms..Downsouthdio wrote:Nice man..hey,are you running heavy weights with that pipe?i blew up 3 fans while trying to get my stroker right with that exact pipe...literally shredded them to pieces.i always ran the light weights with that pipe.they might have been to light lol
Hppowdercoatings
New Goodies on the way from ScooterSwapShop..
Last edited by Hppowdercoatings on Mon Feb 08, 2016 8:46 am, edited 1 time in total.
