How much air is too much/doesnt matter for a 84 Spree?
Locked
lambdafreq
Post by lambdafreq »
It seems a lot of people like to modify the spree's airbox. I've seen a lot of people drilling holes in them and making custom filters. Others have used a UNI or K&N filter. As for those, how big is too big and what size would make the most sense?
Additionally, after rejetting, does it not matter anymore since you're just limiting the air mixture in the carb?
Johnniespeed
Re: How much air is too much/doesnt matter for a 84 Spree?
Post by Johnniespeed »
I have an opposing viewpoint, from all the Sprees I have owned and repaired, I know they run best and perfect, when the air box is perfectly stock and no mods at all.
I also know how they run when an 1984 Aero 50 CDI is installed.
Please feel free to disagree and disprove my experience, as I am sure there must be a way to modify it and get it to start/run perfect again, I just don't know how.
I think the guys who modify their airbox just ignore the imperfect running and mistake the new intake noise for speed. Just like a cold air intake on a car, they only make noise, not power.
Elite 150 64 mph for sale.
Elite 250 77 mph. for sale.
Johnniespeed, I haven't run a Spree yet, but the idea is that the Pilot circuit is TINY in the Spree carb. Its size is built-in, and depends upon high negative pressure - vacuum - in the intake tract to suck enough fuel up that tiny orifice. If that negative pressure is relieved, say, by a hole drilled in the airbox, you won't draw enough fuel to match the air. Even worse if you ditch the box for a pod. Unless you can precisely enlarge the Pilot to match the higher pressure (less vacuum), I agree that it's best to leave the box alone.
lambdafreq
Wheelman-111 wrote:Greetings:
Really interesting, never though about it like that. Thanks!
EDIT: Funny theoretical question:
Say you drilled out the bottom of the fuel tank to add 20% more flow to be proportionate to the air. Then you replaced the airbox with a K&N or something that happened to work 20% better. Then, add a valve to both of those things. Say if you used a magic valve controller that could take it from normal flow to 20% more temporarily, what would happen. I know this is completely redundant and ridiculous, I'm just curious. :P
Keep in mind my knowledge on engineering is very limited and I'm just asking questions.
Johnniespeed
I love riding Spree's a lot, but to go fast I can jump on my Aero 125, my Elite 150 or my Elite 250. Long ago I gave up on trying to force a Spree to go fast and started buying scooters that go faster.
There is nothing you can do to a Spree to get it to ride as nice or as fast as the Big Elites,( I really do like Spree's ) . I don't want to discourage you from trying, but the short cut is very obvious.
You could lengthen the wheel base, add a stroker crank, convert to liquid cooled big bore kit, fabricate fuel injection, fabricate an over-range variator, add disc brakes, add actual forks with shocks, but why ??? You will end up with thousands of dollars invested and hundreds of hours of work, with most likely a substandard result.
patthesoundguy
Post by patthesoundguy »
I have done the testing on an 84 spree with and without the air box with a k&n filter and all of the different jetting. GPS for speed verification and digital tachometer. You will not get any performance gains whatsoever if you remove the airbox and upjet. I had done a little cleaning of the intake ports exhaust port and had the MLM pipe installed. No gains whatsoever! A stock spree works best with the airbox installed with a properly oiled element.
The flow-limiting factor isn't the bottomed of the fuel tank, lambda. That'd be the fixed size of the pilot circuit cast into the little Keihin PA carb body. A steady hand, super-fine gauge wire and a lot of luck would be required to enlarge it. Nobody I have read has succeeded. Mess it up and the carb is toast. Swapping carbs can be done.
lambdafreq
Really interesting, thanks.
Johnniespeed wrote:I love riding Spree's a lot, but to go fast I can jump on my Aero 125, my Elite 150 or my Elite 250. Long ago I gave up on trying to force a Spree to go fast and started buying scooters that go faster.
BEST. COMMENT. EVER.^^
codename47 wrote:all the circuits work to tune it, kind of pretty much. the size of the carb shouldnt, matter so much. the motor should be able to make use of it and no openning of the air box is going to overwhelm the motor. if its undersized compared to the carb, its just restricting it, but the carb if it was way big, would not be able to suck in the choke the amount of air needed to activate the, idle jet main jet.. (choke venturi)..
restricting the air is like popping a smaller carb that the size of the carb on it.
too small of a carb for too big of a motor, would be like turning the mixture screw down too far, and making it oversensitive.
the airbox isnt adding any pressure itcan reduce the amount of air, making it like a smaller carburetor, but not only that making the motor bigger. kinda or whatver, the motors still gonna suck but it makes the motor like bigger, and the carb like smaller and the air will flow through at a faster rate because the engine still needs the air that it requires, but it will be restricted, so it will flow at a higher rate, like the airhole in the mixture screw where it meters the air flow on the pilot jet circuit hole there, and too small, can make it oversensitive. ok i think that's enough analogys. i could make one about breathing thru a straw, and like if you where to like after doing this for 30 seconds used the same straw without takign a breath without useing it, used it to suck pop down and how that wouldnt be normal. someting like that. its still restricted, but nobody would drink pop normally that way.
I disagree... :urban: ...with this^^ dribble.
Especially the part in red.
Johnniespeed
codename47
I don't know what you were smoking or drinking when you wrote that, but I think I need to smoke or drink some too, so when I read it I can understand you.
I think lamdafreq just wants his Spree to go faster and he wants to know the secrets to unleash the power.
Many here on this site have scooters that go fast and know a lot about making that happen, the point that I and others were making, is that drilling holes in the airbox of a stock Spree, will make the scooter run poorly and speed will not increase.
1man8scoots
Post by 1man8scoots »
I feel I must interject here, we're getting carried away with feeling sorry for ourselves.... you need the air box to help create the vacuum draw on the pilot orifice. Simple way for simple people to understand vacuum is do this... Start your favorite shop vac... put your hand over the hose... do you feel 5he engine spin up?... less surface area with the same engine does what? It creates vacuum pressure is what.... take your hand off of the vacuum tube.... what happens then..... engine speed slows..... same freaking concept as your tiny little spree engine.
If you want to blow up or make your spree really junky take the air box off.
If you want to make your spree faster than the local pit bull that chases you...
Mill the head down .5mm, put in a larger main jet, use an sb50 exhaust pipe, use the aero cdi, lose 50 lbs, or run with it to 5 mph while flooring it to get her going. Do not remove the air box or modify it too much. I wouldn't touch it.
1man8scoots
The link the guy provided was to a very well informed members suggestions for big bore kit tuning, NOT stock. I assume we can link things and only read 1/100th of the whole post and see relevance? Pish posh. Some people only see and hear what you want.
I'm neutral with it all until it becomes ridiculous and redundant with extreme falacy. Patthesoundguy is a pro with the spree and I think if anyone should be listened to it would be him.
otto-man
Post by otto-man »
patthesoundguy wrote:I have done the testing on an 84 spree with and without the air box with a k&n filter and all of the different jetting. GPS for speed verification and digital tachometer. You will not get any performance gains whatsoever if you remove the airbox and upjet. I had done a little cleaning of the intake ports exhaust port and had the MLM pipe installed. No gains whatsoever! A stock spree works best with the airbox installed with a properly oiled element.
Well said PTSG!!!!!! You just can't beat a good running Spree :thumbwink:
This seems like a real good place to cap-off this subject.
Any wishes to add to this thread can be addressed to me personally through a pm.
Locked
