Honda reflex 250 smokes and dies when throttled
Ruckenstein
Post by Ruckenstein »
I don't know if I have some coolant lines messed up or what. I got the bike apart and nothing was labeled. It will start and continually emit quite a bit of smoke. I checked the oil reaervoir and there is no coolant. I've been looking for a reflex carb diagram but have not found one. Any help is greatly appreciated!
wentwest
Re: Honda reflex 250 smokes and dies when throttled
Post by wentwest »
There's a coolant line that goes to a preheater on the side of the carb, and a vacuum line that goes from another place right at the carb, and if you get them backwards the bike will send up clouds of steam and run like crap. Any diagram I ever found looked like a dish of spaghetti to me, so I ended up pulling lines one at a time and looking for coolant, and following them. I finally figured it out.
Look at http://www.motorscooterguide.net/Manual ... Manual.pdf for a factory service manual
Ruckenstein
Sounds like my issue!!!!!
Will Inspect when I get time.
What mods have you done, Ruckenstein and wentwest?
wentwest
Post by wentwest »
All I've done is the "K-mod" where you remove 3 weights from the variator to get higher revs at start up. Mostly I like to pick up neglected or broken older scooters or bikes, fix them slowly and then sell them or just ride. This one was cheap for several reasons, but the steaming and bad performance was the big issue. The owner was sure it was a "blown engine". With oil in the sump and turning over and starting normal, I was pretty sure that it wasn't blown, just screwed up. It was, exactly like Ruckenstein's. Swapped the lines and off we went. I might sell it this Spring and look for another. I do about 3 a year.
Ruckenstein
wentwest wrote:All I've done is the "K-mod" where you remove 3 weights from the variator to get higher revs at start up. Mostly I like to pick up neglected or broken older scooters or bikes, fix them slowly and then sell them or just ride. This one was cheap for several reasons, but the steaming and bad performance was the big issue. The owner was sure it was a "blown engine". With oil in the sump and turning over and starting normal, I was pretty sure that it wasn't blown, just screwed up. It was, exactly like Ruckenstein's. Swapped the lines and off we went. I might sell it this Spring and look for another. I do about 3 a year.
What he said. I mean.....exactly what he said. I do mostly buying and selling and I don't even have the registration on my license for a motorcycle. I have a couple bikes that I plan on keeping for the long haul but mostly just buying and reselling.
Ruckenstein
I've tried different combinations and can't even get it to fire now. :/ any ideas?
wentwest
Post by wentwest »
Clean or replace the sparkplug. The vacuum system is really not tolerant of screw ups, so look at page 1-22 of the service manual I gave you the link to. If the vacuum line to the fuel pump is not right, or there's a crack that leaks air, there won't be fuel to the carb.
Ruckenstein
http://www.hondapartshouse.com/oemparts ... carburetor
[img]http://image_www.hondapartshouse.com/oemparts/a/hon/5053e210f870021c54be1a9e/carburetor[/img]
Looking for a little help on how to read the alpha-numeric codes on this page.
It's pretty much out of the service manual and supplier site pages to help verify parts.
I.e. F33 has an inlet and outlet barb. what the Heck is F33
F-31 and E-2 are on the heater barbs bolted to the carb. What the Heck are F31 and E2
Much obliged.
wentwest
Post by wentwest »
F31 and E 2 are the in and out for coolant that heats up the carburetor throat. The piece is just a small casting that bolts to the carb. F33 is a vacuum port. If you think you are seeing in and out there you are looking at F31/E2 instead. You need to be sure that the hoses going to F31/E2 are wet insde and the hose to F33 is dry. Page 1-22 of the manual is helpful, ut not much.
