Spree lost its oomf.
kurremkarm
Post by kurremkarm »
So I have an 84 spree with 5200 miles on it. Had noiseguy's muffler and it was going 33 or so. Then one day it sorta stopped going fast. It just wont get up to speed.
So i cleaned the carb with the seafoam.
Then i Cleaned my air filter.
The i checked my plug and it was fouled, and it was brown with a chunk missing from it. Replaced that plug.
Still sucks. Go into the wind and it wont go past like 23 mph.
So i take another stock muffler that i had lying around and i filled it with seafoam and let it sit. Then i took the garden hose and hosed it out for about 5 minutes. Stuck it on the bike and drove it til it stopped smoking.
Then i got a 12" 1/4 inch drill and drilled out the baffles.
So now i have a spree that will do 25-28 mph. It runs smooth and doesn't hesitate. Starts right up. But this is the same bike that even stock was doing 30 with no problems. That with noiseguys muffler would do 30-34 and now wont go past 24 mph with his pipe on into the wind.
What do you think could be causing this?
mikeb
Post by mikeb »
omg - seafoam in the muffler.
1980 motobecane sebring : 1989 razz : 1985 spree : 1987 spree : 1986 spree : 2002 yamaha vino :1971 cb100 : 1998 civic : 2002 s2000
berreta22
Post by berreta22 »
you said a chunk was missing...did u get it out of the cylinder?
1987 Spree 4400 miles 32 mph stock with my 285lb ***
se50
Post by se50 »
Now you feel like I do on my SE50. :D Cleaned muffler, removed restrictor in clutch (none in muffler), UNI filter, and bigger main jet, and I have no increase in speed whatsoever. Only 25 with no wind. :D
1982 Volkswagen Rabbit 4dr 1.6l diesel (5 speed)
1987 Honda Elite SE50p with drilled out main jet, shaved head, UNI filter
1985 Kawasaki Bayou 185 ATV
1984 Yamaha IT200 enduro
1974 Piaggio/Vespa Ciao moped, pocketbike exhaust.
How's compression?
se50
Post by se50 »
On his Spree or my SE50?
kurremkarm
I dunno i need to find someone who will work on my spree locally.
Unless u think a newb can do his own engine work on these things.
2strokerAce
Post by 2strokerAce »
If you're interested in learning and if you have the right tools I say: "FIX IT YOURSELF!!!" 8)
Just dive right in! Couple of things though:
- Use the right tools
- Use this forum
- Use a shop/service manual
- On a new procedure, document your steps. You think you'll remember the order of assembly, orientation, etc...but you won't. Take pictures if necessary.
- Patience...
If you plan on riding these old 2-strokes for awhile...you'll save $$$ by fixing things yourself -- that's part of the fun!
<b>Scooter: 1989 Honda Elite E
Moped: 1978 Batavus Starflite HS-50
Noped: 1978 Honda Express NC50
Noped: 1982 Honda Express NC50
Wanted: 198x Honda Spree</b>
se50
Post by se50 »
First motorcycle engine I worked on was a Rockford Chibi minibike that was in a box of parts. Second was rebuilding the head on my KLF185 ATV. Motorcycle engines aren't hard to work on, and a scooter is even simpler.
kurremkarm
New symptom. Not a good one. Where the muffler bolts into the engine there is oil leaking out. A fair amount of oil. There is a gasket in the muffler and the bolts are tight.
What the heck?
So let's assume i buy a new scooter, whats a super low maintenance one that has high parts availability and people will work on them?
se50
Post by se50 »
Too much oil being injected into it. Weedeaters do that if you mix the gas like I do (guess, and go heavy on the oil). :D That's my idea.
islandbayy
Post by islandbayy »
Honda Ruckus is Honda's new batch. 4 stroke, so just fill er up with oil, no more auto mix, so an oil change once/year will pretty much be it, and simple to change oil, personally, easier then my generator (I have not done it, but watched).
Elites and Spree's are really low maintance, just that most of us have gotten ours from people who didnt take very good care of them. I was lucky, though, i got my Elite 50 when I was 11, it was used/new, neighbor needed money for his court and lawyer fees (child molestor), so he sold me his Elite 50, that has 120 miles on it, for $1000. Unforunatle though, I didnt know how to maintian it until i was 17. All i knew how to do was to add oil to the resovour, and clean the spark plug, but, cmon, that was 6 years with no maintance :P now I take really good care of it, clean the plug every 250 miles, gets tankly seafoam treetments ^_^
http://KmanScooters.com
http://MilwaukeeEV.com
kurremkarm
We may never know what was wrong with it. Went down to the local dealer today and looked at their kymco agility 50 and various yamahas and what not. Almost dropped a couple grand but then i checked with their service dept and they told me they could rebuild the engine and carb for about 300 bucks so i said, go for it.
I rationalize this as:
1. I don't have to do it.
2. 300 < 2000
3. Why the * not?
