My Spree engine runs.....BACKWARDS????
You're going to need to get some pics of this engine, esp on the fan side. I want to see what's under the fan (spark pickup, etc.)
I'm wondering if the engine is some sort of hodge-podge of parts?
Spirit of 95
- BMX
As I said before, I bought a replacement CDI with no luck. I removed the flywheel to clean up the insides with no luck. There must be a logical reason why this thing will not run in the correct direction. It seems like a timing issue but you can't adjust the timing. What other parts of the motor control timing besides the CDI? HELP ME!!!!!
Like I said...
noiseguy wrote:You're going to need to get some pics of this engine, esp on the fan side. I want to see what's under the fan (spark pickup, etc.)
Spirit of 95
- BMX
I may have missed something, but have you tried cranking it over the opposite direction of what you are doing with the drill?
1982 Volkswagen Rabbit 4dr 1.6l diesel (5 speed)
1987 Honda Elite SE50p with drilled out main jet, shaved head, UNI filter
1985 Kawasaki Bayou 185 ATV
1984 Yamaha IT200 enduro
1974 Piaggio/Vespa Ciao moped, pocketbike exhaust.
Spirit of 95
- BMX
Yes....once I realized I was cranking the engine in the wrong way I switched direction. It won't run the correct way. Just backwards...not well mind you. It will rev up but not with a lot of power. Like I said...it seems to be a timing issue that is more correct running backwards than forwards. I do not know the history of the Spree before I bought it. It might have parts that are not right for it. I have pictures people can see if that will help. I have been trying to get this to run since April and I need ideas.
Email me the pics or post them on a free site and link them to a post here.
Spirit of 95
- BMX
Here are some pictures with the flywheel off.
http://www.imagehosting.us/index.php?ac ... nt=1501299
http://www.imagehosting.us/index.php?ac ... nt=1501296
http://www.imagehosting.us/index.php?ac ... nt=1501307
OK. Now need a pic of the flywheel and the year of your scoot. Guessing yours is an 84/85 based on the pickup. Get a shot of the pickup, the little chuck of steel that sticks out from the side of the flywheel, maybe it's damaged.
I still think the issue is in the induction system (dirty idle jet, unsealed bystarter, reeds, or air filter box) but we'll run this course a bit.
Spirit of 95
- BMX
Spirit of 95
- BMX
Ok....here's pictures of the flywheel
http://www.imagehosting.us/index.php?ac ... nt=1501986
http://www.imagehosting.us/index.php?ac ... nt=1501981
