UK Honda Vision NE50 MF - newbie performance advice sought
Re: UK Honda Vision NE50 MF - newbie performance advice soug
I've been reading on some forums that the engine in the Vision/Aero (presumably AF50E) is the same as the Peugot Speedfight 1 & 2. Does anybody know this to be true. If so will the Gianelli exhausts fit?
Looking at the Gianelli website, they list 2 pipes for the Speedfight 50 air/liquid. The first (Rekord) doesn't look like it will fit
however the second (Reverse), looks like it might
The Rekord is way out. The second one is close but I reckon the header would need to move (away) a bit. I could be wrong though. I will need a new exhaust as I have found a hole in mine. Couldn't see any restricting washer inthe header though.
I think I'm gonna go for the proma chamber pipe from Italy now that the Malossi wild lion is out of production.
I'm interested to see this Proma pipe and if it fits ok. Could be a way for me to go too. Good luck with it all mate
Going through your photos again and noticed your transmission has Made in France (mine hasn't) on it and no HONDA moulded into the transmission cover (mine has).
welder steve
- Goped
that looks like a Peugeot copy/ i believe they made alot of stuff for honda. looks like a speedfight style but af05, i believe the speedfight uses a af16e style cyl and intake
fattaffracingco
hi , good thread this chaps it has cleared up a few things for me with the differences between USA and UK spec models
speedfight exhaust does not bolt on ! I fitted an old speedfight yasuni pipe but I had to cut n weld vision flange on it , not a massive job but a couple of hours work all in all
yasuni pipe nice thick gauge metal ,lovely to weld, but errr bit noisy innit ?
great thread tho , for us brits
Just starting out on the same quest to squeeze a few more mph from my '85 Vision when I came across this thread. I'm wondering if anyone has found a restricting spacer in the variator from a UK Vision with an AF05E motor? I can only get about 27mph but from what I've read elsewhere I should be able to reach 35 with this motor.
Depending on mileage, you may have a fouled air filter, low compression, or a caked-up exhaust. Remedy these first. Your AF05 should indeed get to 35 and do it pretty quickly. It's possible that there are restrictions on the English models we've never seen in the States. AFAIK there's never been any restrictions on the AERO models sold here. Check the exhaust pipe for a restricting washer welded in, and check the manifold tube for the same.
If you can find a Malossi, Polini, or Keli variator for AF05, buy and install with a new belt. Service the driven pulley if it feels sticky. With nominal power you can get close to 40.
It's quite likely that there's a fair amount of carbon built up inside which would account for a few MPH, but the big clue is '30MPH' printed on the ID plate. This is what allows it to be classed as a 'moped' in the UK so it can be driven by 16 year olds and people with a car licence. There's a restriction somewhere and from reading elsewhere on here about a French version it's probably the variator ramp plate which is apparently almost flat, but I wondered if maybe there's a spacer in there as well / instead. I took the exhaust off to change the tyre and there's no restriction in the header.
If anyone has a used standard ramp plate in fair condition for an AF05 that they no no longer need, please let me know? Or if anyone has a photo or part numbers they could post, I can compare it with the one I have.
Thanks
Thanks
http://hondaspree.net/wiki/index.php5?t ... erformancecancunia wrote: Or if anyone has a photo or part numbers they could post, I can compare it with the one I have.
The only way to know is to take off your vari and look. Post pics of it here if you can. On U.S. Hondas, the "flattened" ramp plate was only used as a restriction method for a limited number of years/models. The vast majority of restricted bikes had a washer that can simply be removed.
The restricting washer (if any) would be in the exhaust itself, not in the header. A proper size drill bit is used to drill it out.cancunia wrote:I took the exhaust off to change the tyre and there's no restriction in the header.
Thanks for the wiki links, from the pictures the ramp plate differences are totally clear and if mine is anything similar it explains a lot. Do those ramp plates also fit an AF05 motor? . Restricted European exhausts normally have a washer right at the top of the header but it's worth checking the whole thing over so I'll take another look at the exhaust.
I need to go past a scooter shop sometime next week and I'll pick up a new belt while I'm there. The shop is mostly about classic Italian scooters, but they may know about ramp plates. When I have the belt I'll take a few pix of the ramp plate.
Ive got some ramp plates if ya need them.Also one sa50p front boss thingy
Thanks, I'll send you a PM.jakubman1 wrote:Ive got some ramp plates if ya need them.Also one sa50p front boss thingy
