Honda Express.... Where to begin
Re: Honda Express.... Where to begin
One more quick question.. What is top speed on these. Stock with no mods?
- patthesoundguy
Mine went about 30mph or there abouts
So what does it require as far as installation to install a big bore kit? And do I need to worry about upgrading my carb or any other parts if I do go with a big bore kit?
- patthesoundguy
You totally will need a larger carb for sure as the stock carb is kinda small and most express carbs have a fixed main jet. You can get intake adapters or entire intakes. This is prob a good way to get a bigger carb https://www.treatland.tv/MLM-honda-expr ... ke-345.htm bolt it on bolt on a new carb and throttle cable and rock. The real magic comes from a pipe though. Pretty much you bolt on the kit bolt on the carb get the jetting dialed in and start breaking it in. Make sure you run premix along with the stock oil pump. Crap I just remembered some important info for bolting on a bbk to an express. Since the cylinders are meant for a pa50 you may have to cut fins to make clearance for that oil plug on the trans case.
And you don't need to but it could be a good idea to block the compression release hole with a pics of bolt and tap the hole.
Wow! thanks! I think I am going to go that route and try to add a little more power.
- patthesoundguy
It adds a lot of power but costs a boatload of money depending what parts you decide on.
Thanks. I looked into all the upgrades.... Wow it does get pricey. Maybe I will forget about the big bore kit for now and think about it if my rebuild fails down the line.
the exhaust port on my express is smaller than a spree exhausts port. patthesound guy is also one of the best on this fourm so id take his advice.
I'd start with opening up the exhaust port and a new pipe.
- patthesoundguy
Hey thanksmmeadows wrote:the exhaust port on my express is smaller than a spree exhausts port. patthesound guy is also one of the best on this fourm so id take his advice.
