what are my options as far as a head gasket with the corsa? where can I get afew of those circle band things the corsa uses? I saw a gasket kit on ebay is that the only way?
Sent from my SCH-I500 using Tapatalk 2
polini corsa head gasket?
- paulpauly7
Re: polini corsa head gasket?
you can use a stock headgasket just open up the center hole up to 47mm to match the corsa.Any good machine shop should be able to supply the viton O ring
t8kinover.
- BMX
ok thanks the gasket kit daywoot sells for 19.99 would supply the head gasket I hope?
The polini o-ring gasket should last at least 45,000 mi. i can get you one for $25 the contessa runs a standard metal gasket.
t8kinover.
- BMX
is the o ring reusable after you open the head?
- paulpauly7
yes
