Spree Engine Swap: Honda Elite CH80 onto Spree
Tyler VR
Re: Spree Engine Swap: Honda Elite CH80 onto Spree
Post by Tyler VR »
Back on the scooter, only the bottom will show once the side plastic is on.
Dalrock
Post by Dalrock »
Tyler - how do I contact the fella you traded the Elite 80 body parts to? I need the front cover and knob which connects to the side covers.
Tyler VR
Post by Tyler VR »
Dalrock wrote:Tyler - how do I contact the fella you traded the Elite 80 body parts to? I need the front cover and knob which connects to the side covers.
I'm sorry, I don't think he ships.
Tyler VR
Post by Tyler VR »
I removed the carb from my spare ch80 and cleaned it up. I also installed bigger slow and main jets I got from Jetsrus.com
Runs a lot better and I got the top speed back after it was reduced because of the exhaust pipe and air filter. :thumbwink:
Now I'm going to focus on getting everything painted.
Tyler VR
Post by Tyler VR »
Spent some time doing paint work, lots of sanding/prepping. Took these pics just prior to spraying.
Kevinstonge
Post by Kevinstonge »
[quote="Tyler VR"]I removed the carb from my spare ch80 and cleaned it up. I also installed bigger slow and main jets I got from Jetsrus.com
How large did you end up going with the jets? Also do you know what the stock pilot jet size is? Thanks!
Tyler VR
Post by Tyler VR »
Kevinstonge wrote: How large did you end up going with the jets? Also do you know what the stock pilot jet size is? Thanks!
Here's where I got the jets:
http://www.jetsrus.com/a_jet_kit_scoote ... _elite.htm
TYPICAL JET SIZE:
Main Jet - 88*
Slow Jet - 40*
I went up to a 45 slow jet and got 90,92,95 main jets to try.
Tyler VR
Post by Tyler VR »
I had the front shield nearly done painted and it fell from my crappy hanger line. All sorts of marks/scratches in my fresh wet paint. :x
So I'm going to have to sand it back down and repaint.
Your thoroughness is admirable. Eager to see results!
Tyler VR
Post by Tyler VR »
About to spray the side panels, there were a lot of scratches hiding under those stickers.
Tyler VR
Post by Tyler VR »
On the floorboard I decided not paint the textured area because it would most likely rub off. But I did clean the area using a couple methods before I masked it off.
Tyler VR
Post by Tyler VR »
Painted the turn signal housings and some of the other smaller pieces too.
Tyler VR
Post by Tyler VR »
Here's all the painted body parts, turned out good. Planning on painting the frame this weekend.
Tyler VR
Post by Tyler VR »
Frame painted, I made sure to plug/mask all the threaded parts.
Tyler VR
Post by Tyler VR »
Forks and handle bars painted too.
