should gas be in vacuum line
spree will only start will starting fluid
I can get running with starting fluid. Does this sound like a choke issue carb issue vacuum line.
jwright0291
Re: spree will only start will starting fluid
Carb gummed up my guess
Never ever use starting fluid on a two stroke.
It strips the oil off the cylinder walls and piston . You are ruining your engine.
If you have to prime the engine, use a premix of gas and oil at a 32 to 1 ratio.
I agree, clean your carb.
http://hondaspree.net/wiki/index.php5?t ... r_Cleaning
and
http://hondaspree.net/wiki/index.php5?t ... ture_Guide
If that does not work, clean it again.
and
Re: spree will only start with starting fluid
Will run fine once started with starting fluid. Plug is dry when I check it after trying to start without starting fluid. Carb? Choke? Vacuum line? All of the above?
Bystarter is probably plugged in the passage from the bowl to the bystarter bowl. CLEAN THE CARB!jme wrote:Will run fine once started with starting fluid. Plug is dry when I check it after trying to start without starting fluid. Carb? Choke? Vacuum line? All of the above?
throdle cable trouble
Took car apart for cleaning now the throdle cable isn't working :right
Re: throdle cable trouble
Chances are you installed the slide wrong. The long full length slot on the slide goes to the engine side of the carb to engage the nub inside the slide bore. If it does not the slide does not go all the way down into the carb.
I cleaned my carb and my spree is still running like crap. Gas isn't getting into the head plug is dry. Has a hard time starting. I can see a small amount of gas in the vacuum line. Any ideas?
Re: should gas be in vacuum line
So clean the carb again. Noobees usually take about three tries before they get it right.jme wrote:I cleaned my carb and my spree is still running like crap. Gas isn't getting into the head plug is dry. Has a hard time starting. I can see a small amount of gas in the vacuum line. Any ideas?
and
If the fuel is bouncing around at the bottom of the vacuum line next to the intake nipple , that is normal. If it is running down from the petcock, then the petcock is bad.
- kingkamehameha
Bear loves these kinda threads. Troubleshooting guru
