Duke250
Re: Need a quick help For my friends Honda Elite .
Post by Duke250 »
I leave in Wisconsin .
dun rite
Post by dun rite »
cheapcycleparts.com lists 16155-GZ5-000 (believe this is a honda number) as the part number for the 94 and up float valve. check the part number they gave you. But do consider new fuel and vacuum lines and a filter
As Trafficjamz said. no more starting fluid, use a premix fuel to prime.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
if it is leaking while the engine is off, a new petcock may be on that shopping list.
Duke250
Post by Duke250 »
it is only leaking when it is running. The honda dealers order me the wrong inlet. They order me the one for Honda elite 1988. Now they were going to order me the right part but it is 25 bucks plus taxes. I also look it on that sites http://www.cheapcycleparts.com and it is the same price. I change my mind I am just going to order the whole carburetor on ebay . I saw it is 32 bucks plus shipping. ANy ideas ?
dun rite
Post by dun rite »
Trafficjamz wrote:i might have one
PM trafficjamz, says he might have one.
arreche air filter
v8 pipe
stock gears
Duke250
Post by Duke250 »
just did thanks waiting for his reply
Duke250
Re: New Carb On my $50.00 1998 Honda Elite SA50p
Post by Duke250 »
:peace: :rock: New Carb On my $50.00 1998 Honda Elite SA50p
2 days ago I've decided to just go ahead and buy a new carburetor instead of the float valve. When I think back buying just a float valve for $25.00 that is allot of money for just a small tiny thing. I bought a brand new one one ebay for $34.00 and free shipping. It came in the mail today . So I tried it and man it make a big change. I got it start on first kick and one pouch and it fire up on electric .
I had took it for a ride .It runs great and good speed and then I looked at the speedometer and and it seems like it is not working. The oil light is not ON and I think the fuel gauge is working .So any ideas on how to get my speedometer working. So tomorrow I will be getting myself ready to start my spray paint job.
dun rite
Post by dun rite »
glad you got it going. for speedo you need to check the cable, possible stripped gears on the wheel end. hard to say. Hope you have good luck with that carb.
arreche air filter
v8 pipe
stock gears
Duke250
Post by Duke250 »
Thanks with out your help I wouldn't be able to get it working .Stripped gears what Is that ? Also I know it it not my speedometer because my signal lights are showing on there and so does my front light when I do high beam and low beam .
dun rite
Post by dun rite »
did you ever download or look at the manual: find it here: http://www.hondaspree.net/other/SA50_88-02_service.pdf
section 12 page 8 shows the speedo drive gear. A cable slides into it and than goes to the speedo. the gear could be stripped, the cable could be broke. Or it could all just need attention. the speedo is not electrical.
arreche air filter
v8 pipe
stock gears
Duke250
Post by Duke250 »
Hey guys what is the best oil to used on a 1998 SA50P Honda Elite. Also i am getting allot of black smoke. Any Ideas what is causing that?
Like THis kind of plastic what is the best way to paint them? What I don't want is for them to look to glossy. i want to paint it and make look like like the way it was before. What is the best paint for it . I also don't want to used bed liner on them . I am going to paint them all black and the body a night blue or a sport red . I haven't decide yet .Peaceeeeeee
dun rite
Post by dun rite »
if you don't want it shiny then use a flat black or satin. but painting on the floor boards will come off after some use.
arreche air filter
v8 pipe
stock gears
Duke250
Post by Duke250 »
Thank you I guest I am ready to paint now . I am trying to find Urethane Supply Company's hardset epoxy filler . I had repair some crack with fiberglass repair but don't know what type of epoxy filler to buy. I think it is a gray color thing and then need to sand down when dry . Dun Rite thanks allot for helping peace to you .
dun rite
Post by dun rite »
here's a plastic repair topic in the wiki http://hondaspree.net/wiki/index.php5?t ... tic_Repair
arreche air filter
v8 pipe
stock gears
bonesv
Post by bonesv »
Happy for your progress. Good luck with the paint job, on my last build,
I used a flex bumper and trim paint with adhesion promoter primer. Not glossy.
I might try a matte clear coat to give it some protection.
:peace:
