Spree question!!!!
Spree question!!!!
How similiar are the 85 and 86 spree? Will brake cables fit from one to another? Starter? If someone could help i would appreciate it. Thank you. Pretty much what can be interchanged between the two different years.
Re: Spree question!!!!
Hi,
84/85 Spree interchange is better. Honda made a lot of changes in the Spree line in 86 and again in '87. The SB50 Elite E replaced the Spree in 88/89, and has it's own flavor of part differences. If you are searching for parts compatibility, please check our compatibility thread here and add info as you find it.
Be careful about brake cables and starters from '85 to 86. It has seemed from member feedback that there were changes, but the parts bin was not completely flushed when the '86 model year started. So take a good look at parts you have, and ask questions to sellers for dimensions etc.85 and 86 spree? Will brake cables fit from one to another? Starter?
