what's the harm of running a spree with no bystarter
stankyoleman
what's the harm of running a spree with no bystarter on at all, just the empty port
- Farfignugin
stankyoleman
wierd thing is, mine will actually start ok without one (i have a kickstart, no electric start), and a non-plugged port (completely open).
after it starts up, it idles real high, then back down alittle but still pretty high, and if i completely 100% block the hole with my thumb it dies.
reason i'm asking is because i have a bad bystarter, as in the needle is gone, and i think an o-ring might be warped possible... and i wanted to know what the best thing to do, because i don't seem to be getting as much out of the engine in terms of top end speed as i think i should.
stankyoleman
- Farfignugin
Or Myspree's carb was just completely jacked up. Don't run w/o plugging the bystarter up with a pin, lots of air gaps and a fuel port there.
