Tru72... I like see that special something lmk SHAKAS!!
'89 Honda Elite E dio
Re: '89 Honda Elite E dio
Wheelman111 thanks for your concern it seems to work like the stock mount would an I am a heavy weight an it holds up fine but yes caution is a must at all times when you ride anything thanks. SHAKAS!!
This is how she's looking now...
- gixxer1000chad
d*** bro, niiiice job.. keep up the good work.. i never would have guess it would look that good especially the way it looked b4
i bet mine is slower!!! now what??
Thanks gixxer1000chad... I kno it turned out not bad at all now just have to put in one 49mm nickel seal an one carb an intake then we see how she roll till then i have to work on the tail light SHAKAS!!
All i can say is BADASS
DJ1
NEK MINNIT
Malossi
DJ1 54mph
dio gear swap in progress
living in chch NZ
earthquake central
NEK MINNIT
Malossi
DJ1 54mph
living in chch NZ
earthquake central
A tip of the Wheel-hat for your great cosmetic and Scooter Hygiene work.
I noticed the belt cover appears to be cut straight across - no rear cover screw projection: Is that an SA/16 or an SE/05?
I believe that is a SYM block
Quoth Mystic:
Quoth Mystic:
Ah, that would explain it. Sorry I didn't re-read from the beginning.I believe that is a SYM block
That a dodo50 from sym it is a good motor!
Sym dd50. Used pb carb.
Yes guys! It is a SYM motor. Wheelman I got the motor with the cut cover an I like the look.
All most finish on that tail light will have some pics of light up soon till then SHAKAS!!
Well this bike was sold..
Have a interesting story about it.
beginning of the week , this guy shows up at the shop with the bike, Says he was riding it and it died on him. Took it in and checked it out later in the day. No compression, lol you know thats a bad sign. Pull the bore and see the wrist pin clip is gone, bore is toast. Call him up and tell him i need to split the block to make sure the clip isnt in there, he says ok. Split the case and find the rest of the clip, rod totally sloppy, bearings all burnt. Cal him them him that the bearing, seals, crank needs to be replaced as well. I told him i have a extra crank ill give him, he says ok. Well yesterday , friday he appears and hands me over the title for the bike saying that he can afford to repair it and wanted to give it to me instead of just not showing up. Of course i told him if i was sure and asked whats going on , if he wants to makes payments on the repair.. Found out that he he is here for like 4 months just cruising around and was planning to sell it anyways lol. He said thats ok its mines. Told me that it was karma that told him to give it to me lol! Shocking, even my boss was blown away. So for a few hundred bucks worth or labor and parts i hav a new bike . Funny i told my self this year I would not buy any more projects lol.
Oh wells that really made my new years!
Aloha
D
Aloha
D
wow O_o'
SWAG
1984 Honda Spree
1985 Honda Gyro S
1977 Honda Camino
1960 Alpa Moor
2009 Piaggio MP3 400
2002 BMW 330xi
1984 Honda Spree
1985 Honda Gyro S
1977 Honda Camino
1960 Alpa Moor
2002 BMW 330xi
