1983 Aero 50 hard start when cold
- spree picker
- BMX
I PICKED UP A 83 aero with 795 miles runs great after I get it started but when it sits for awhile hard to start very long crank if i give it any gas it dies,after several tries it starts
I give old Sprees a new life
- swimmingfree
Re: 1983 Aero 50 hard start when cold
you bystarter may be bad..
do a compression test as well it wont hurt..
- spree picker
- BMX
the bystarter test good like 5 ohms
- swimmingfree
im no you read it a lot but clean the carb... if the hole blow the bystarter is plug it may be what is going on
I agree with swimming free, also check to make sure the o-ring on the bystarter isnt cracked or damaged
I've got two '83s and they both have this problem. One though, after riding it more frequently, the problem seems to be subsiding. Either way, when you clean the carb, note the pinhole orifice in the float bowl, and the emulsion tube that just presses in the carb under the mainjet. These are both easily overlooked. I think air screw setting may have helped too.
RZ Rob
RZ Rob
- spree picker
- BMX
- swimmingfree
there is a small hole you can see when you look now were the slide goes its the hard part to get clean if you cant see thou it its not clean anuff use compress air or a spray cleaner to make sure its clean
- spree picker
- BMX
Ok,took carb apart everything got blown out good will put back together tomorrow.I didn't seen any restriction wish me luck!
RZRob wrote:I've got two '83s and they both have this problem. One though, after riding it more frequently, the problem seems to be subsiding. Either way, when you clean the carb, note the pinhole orifice in the float bowl, and the emulsion tube that just presses in the carb under the mainjet. These are both easily overlooked. I think air screw setting may have helped too.
RZ Rob
1983's??????? I don't think so.
Bear, Why doubt ye the eighty-three? Could be '84s I guess. One thing's for sure: They're WAAAAYY cleaner than any scooter that old has any right to be! Nice quiver, RZ.
- spree picker
- BMX
looks like 83 to me,as far as clean * yea I have 2 84 gyros and 2 85 sprees just as clean.Very nice collection thanks for the pics.
Because I didn't look close at the picture and it bit me in the butt.
- spree picker
- BMX
soaked and cleaned,rode last night .It started up this morning looks like I'm riding the old girl to work.
