My 1985 Aero 50 is super hard to start after it sits for 2 days or more. It doesn't even really fire and usually when I crank on it for a long time (multiple minutes) it will start to fire and eventually start. If I start it everyday it starts almost immediately. I tested my auto bystarter by removing it and putting 12V on it and it did heat up and move out. I also pulled the vacuum line and gas line off the carb, sucked lightly on vacuum line and gas flowed. Any ideas? This morning I cranked so long that my new gel sealed battery started to die, now I have to buy a charger
No Spark, Bad Exciter Coil I believe
*update 2/24/12...My original thread post is below, I found that the alternator exciter coil is believed to be open at this point.
- bradmeehan
Re: Aero 50 really hard to start after it sits for 2 days or
My experience with those symptoms is the carb seals are dried out and it's sucking air there. That would also allow the gas in the bowl to evaporate and have to refill when you crank it. You can get carb rebuild kits that include all of the seals.
1986 Spree
1986 Spree (Big Bore)
1985 Aero 50
1985 Aero 80
1988 Elite 50 (SB50)
1985 "OrangeJuice" (Sold)
1985 Aero 50
1985 Aero 80
+1
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
Either that or the petcock is bad along with the needle and seat and the engine is flooded. Crank it for about 5 seconds, pull the plug; dry = the first issue, wet = the second.
FYI, my 1985 Spree always takes about20 seconds of crank to start after it sits for a couple days or a week or months.
Thanks for the advise. I will say that I did a complete carb tear down and cleaning a few months ago, it ran a little better but the starting issue was the same. I did not see any dry seals/gaskets and I have tried spraying carb and choke cleaner all around the carb when the scooter is idling, it did not change RPMs at all.
- SuprasNsprees
Bear45-70 wrote: FYI, my 1985 Spree always takes about20 seconds of crank to start after it sits for a couple days or a week or months.
+1
and i've got a freshly rebuilt carb , and a brand new battery
'80 Puch Magnum MKII
'78 PA50 Hobbit
'78 PA50 Hobbit
Mine is minutes though, if I start it everyday it fires after only a few cranks (1-2 seconds).SuprasNsprees wrote:Bear45-70 wrote: FYI, my 1985 Spree always takes about20 seconds of crank to start after it sits for a couple days or a week or months.
+1
Are you opening the throttle while starting?
YeahBear45-70 wrote:Are you opening the throttle while starting?
I tried cranking for about 5 seconds with open throttle and pulled the plug, it looked a little wet but was kind of hard to tell. It certainly wasn't either extreme, dry or dripping. I put the plug back in and cranked some more and it looked the same the second time around.
Cold starts require that the throttle be CLOSED or the bystarter will not supply extra fuel for the cold start. Warm starts often require added throttle. Cold never.
Really? Wow, that's interesting, I had no clue. Guess I'll try cranking without touching the throttle when I get home, thanks.Bear45-70 wrote:Cold starts require that the throttle be CLOSED or the bystarter will not supply extra fuel for the cold start. Warm starts often require added throttle. Cold never.
To pull the fuel from the bystarter bowl requires vacuum, opening the throttle lowers the intake vacuum, hence no extra fuel for the cold start.DKAudio wrote:Really? Wow, that's interesting, I had no clue. Guess I'll try cranking without touching the throttle when I get home, thanks.Bear45-70 wrote:Cold starts require that the throttle be CLOSED or the bystarter will not supply extra fuel for the cold start. Warm starts often require added throttle. Cold never.
The owner's manual specifically states "4. With the throttle closed, push the starter button (4). Release the starter button as soon as the engine starts.
NOTE:
Do not use the electric starter for 5 seconds at a time. Release the starter button for approximately 10 seconds before pressing it again."
Well, I found that I don't have spark. I did some resistance readings per the manual...
The coil resistance seems fine.
The pulse generator was good, about 160 ohms.
The alternator excited coil gave me a reading in the mega ohms.
Should I replace that or do you have any other troubleshooting tips to make sure?
Bear45-70 wrote:DKAudio wrote:[quote="Bear45-70
NOTE:
are the owners manuals archived somewhere on here like the service manuals?
1985 HONDA AERO
1986 HONDA SPREE
1986 HONDA SPREE
Some of the owners manuals are in the service and owners manual section.maxreverb wrote:Bear45-70 wrote:DKAudio wrote:[quote="Bear45-70
NOTE:
