ok
you whiz kids
She's a1988 SB50P. I recently put in a 44mm top end kit. Compression is good. I've got over 30 mi on the upgrade but it runs like shxt at from 25-32mph. It bucks like a wild horse unless I adjust the air mixture screw all the way in (clockwise). The kit came with a #68 jet which I installed. The kit suggested putting a couple extra 1"holes in the air filter. I have Closed up all but one hole just to get it to run at higher rpm's. Any idea's? HELP
New jets or not
Re: New jets or not
Yeah, it is obvious, with the holes close you are too rich.
steve beddow
Re: New jets or not
Are you saying I should reopen the holes I made
Re: New jets or not
so with all but 1 hole closed and the air/fuel screw turned in is the only way the engine will get to the high rpm's? have you tried closing all the holes and turning the air/fuel screw to the factory set point(1 1/2-1 3/4)?
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
91 yamaha tzr 250r
steve beddow
Re: New jets or not
I DID THAT THIS MORNING. FIRST i OPENED UP TWO HOLES. WOULD IDLE OK BUT REVING UP SHE JUST BOGGED DOWN. NO MATTER WHAT I SET THE SCREW IT WOULDN'T RUN. JUST BOGGED DOWN WHEN THROTTLED UP. SO THEN I PUT ON A FACTORY STOCK FILTER. IT STILL WOULDN'T RUN. NOW IT WON'T START WITH NONMODIFIED FILTER. BUT IT MAYBE FLOODED SO I WALKED AWAY FROM IT FOR A COUPLE HOURS. I'LL GET BACK LATER.
Re: New jets or not
check out this guide on carb. tuning. http://enigma.lhosting.info/carbtune.html
might help. it's for larger carbs but should be same steps for our smaller ones.
arreche air filter
Naruku intake, reeds & block
v8 pipe
stock gears
trail tech temp & rpm gauges
arreche air filter
v8 pipe
stock gears
