1999 zuma upgrade options
Can these be made fast?
60mph goal reasonable? :confused:
SpreeMadness520
Re: 1999 zuma upgrade options
Post by SpreeMadness520 »
Part out that yamaha piece of * man lol joking
130cc Stroker
1984 Porsche 944
1965 Vespa
http://cgi.ebay.com/ebaymotors/POLINI-7 ... arQ5fParts
Does this kit fit this zuma?
That would probably make it get up and go. :surprise:
What pipe is a good match for this?
Trafficjamz wrote:http://cgi.ebay.com/ebaymotors/POLINI-7 ... arQ5fParts
It had better make that scooter into a Le Man racer for $505 with shipping. :shock:
There are less expensive ones out there :wink:
Still can't find the pipes for the vertical minerelli :confused:
bakaracer
Post by bakaracer »
yeah that fits. here is the exhaust
http://cgi.ebay.com/ebaymotors/YAMAHA-Z ... 3a4bcf054b
Nothing like getting stroked!
Thanks to my sponsors
90 honda dio sp 72cc
91 yamaha tzr 250r
Post by eliteguy50 »
IMO, the Zuma II with disc is better than the Bugeye Zuma. If you are looking for a kit on the cheap, Limp still has some BBK's.
fastplastic
Post by fastplastic »
swap a dio, show mr. E what cheap powers all about lol :2thumbs:
fastplastic wrote:swap a dio, show mr. E what cheap powers all about lol :2thumbs:
Better off swapping a zx50 so it will be a long case.
bakaracer
Post by bakaracer »
eliteguy50 wrote:IMO, the Zuma II with disc is better than the Bugeye Zuma. If you are looking for a kit on the cheap, Limp still has some BBK's.
yeah plus they are lighter by about 40lbs and lots of aftermarket engine and body parts.
91 yamaha tzr 250r
They also have a shorter wheelbase with a lower COG. As long as you don't need the underseat storage or capacity to move 500# around, I like the Zuma II. Think about your jog and then compare that to the modern Zuma. The Zuma II is in between those two.
I don't know what the budget for this project will be yet.
The goal is 60mph top speed. Can that be done for $600-$800?
Parts are more expensive for this model (the market is no longer flooded like it is the bug eye Zuma). It can be done for sure if you are willing to use a Taiwan bore. It will be tight to do it with Italian parts. A good crank will really swing it, the Taiwan cranks will not hold up for 60 mph runs.
Baka- I know the '99 Jogs had switched to the Taiwan cranks but did the Vertical Zuma switch over too?
SpreeMadness520
Is this for the same guy I smoked on the jog?
130cc Stroker
1984 Porsche 944
1965 Vespa
SpreeMadness520 wrote:Is this for the same guy I smoked on the jog?
Yes.....Well for his girlfriend actually.
