take the Iowa out of my spree
snappy
Post by snappy »
is it true you can drill out the exhaust and gain a few mph on a 85 spree
Re: take the Iowa out of my spree
If it is an Iowa Spree, yes but you have to change the main jet to the 68 used in the standard Spree or you will run lean.
Storm
Post by Storm »
Assuming I understand this right,
if I already have a 68 main jet, theres nothing to be gained by butchering the muffler (apart from sore ears) ?
Not one day that we are here on this earth is promised to us, so treat every day as if it is your last, and every breath as if it were the same
198? Honda Spree NQ50M (got parts of two different bike mixed up in there!)
Storm wrote:Assuming I understand this right,
The drilling out of the exhaust only applies if your muffler has the restrictor washer welded in the opening of the exhaust pipe where the pipe bolts to the exhaust port on the cylinder. Drilling the muffler else where is a waste of time and hard on the ears and can get you ticketed.
Storm
Post by Storm »
What size should the opening be sans washer? Will be taking a look next time 'I'm in the shed
Storm wrote:What size should the opening be sans washer? Will be taking a look next time 'I'm in the shed
Does not matter, if the washer is there it is obvious because it is welded over the opening and you just remove all traces of it.
