had to put hand on carb as a choke
snappy
Post by snappy »
I had my carb apart to clean it.It was running fine .Would not start back up.Put my hand on carb then it started.It's been sitting for a couple of days wouldn't start again put hand on carb now good to go any advice?
odinxxix
Re: had to put hand on carb as a choke
Post by odinxxix »
are you useing the airbox? if not you should be
1986 honda spree(silver fox)
BBK
85 head
SB50 intake
SB50 reeds
taz gears
2.75X10 tires
2000 honda elite S
prodigy vari
2k grabber clutch springs
9:1 gears
jdm tail lite
1982 suzuki FA50
If this is a Spree, it is not uncommon for them to not start with no air box.
snappy
Post by snappy »
Yes I have the air box on.
fastplastic
Post by fastplastic »
might have an air leak not sure need more details
snappy wrote:Yes I have the air box on.
Then how did you put your hand over the carb.
snappy
Post by snappy »
I took the tube off and choke it out put it back on and it ran great.
devenex
Post by devenex »
Make sure your pilot/idle jet is clear. The little tube that sticks down into the bowl that is next to the main jet.
I'd recommend cleaning the entire carb one more time, paying special attention to that small and very easily clogged jet. If carb cleaner can spray though it from the bottom and mist nicely out the top then its clear.
1986 Spree w/ '87 SE50 motor
