About a month ago I put in a big bore kit. First time it fired right up and idled fine. Turned it off and since then I haven't been able to start it. Originally my starter motor didn't seem to have enough power to turn it over but I believe that was caused by my kick starter gears being in the way. I recently replaced all the kick starter parts and now that seems to work along with my electric starter. Now I have no spark. Tried a new spark plug and that didn't work. Bought a $50 parts spree and swapped over all of its electrical parts and still no spark. Any thoughts?
Thanks.
No spark.
Re: No spark.
check the main fuse,coil,cdi unit,
maby your harnes is not getting a good ground
spree parts for sale
still learning alot ..thanks to all on this fourm
if you have a good spree jug ..pm me if you want to sell it
Re: No spark.
Hold the left brake lever?
2001 Honda Elite
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
1995 Yamaha Jog
1994 Yamaha Axis
I can't believe
that cop put me
in the backseat
when I clearly
called shotgun.
Re: No spark.
Make sure the "Stop/Run" switch is in the Run position.
Re: No spark.
Turns out that when we were checking the starter, a ground wire came loose. Looks like the previous owner rigged it up with electrical tape. Reground the wire and now will begin breaking in the BBK.
Thanks for the suggestions.
92 Honda Elite SR
-Ruckus Variator Mod
93 Honda Elite SR
93 Honda Elite SR
- martynkim
Re: No spark.
sjleto wrote:Turns out that when we were checking the starter, a ground wire came loose. Looks like the previous owner rigged it up with electrical tape. Reground the wire and now will begin breaking in the BBK.
I was gonna say GAS in the tank? Then I saw this post....
Re: No spark.
haha what i say
