Great job!
spree-dio swap time!!!
- Petrock's 1984 Spree
Re: spree-dio swap time!!!
Wow, looks professional to me!
Great job!
Great job!
Complete NOOB, sorry dudes
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-Polini 2 Shoe Clutch
-Koso Vented Clutch Bell
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Well, I got the boost port cut today, and prepped everything to put the crank in. The port has been adjusted a little bit, and the engine should be running by next week.
I also bought a lifted 91 subaru legacy, my 5th Subaru.
Ol' Red
Broken...
Spreeio
1987 Spree
With af16e powah!!!!
Broken...
Spreeio
1987 Spree
Well, the crank is in the engine, the hondabond is cured. Brand new Honda OEM NSK bearings now are nestled on either side of a 44.4mm Teflon stuffed Ruima crank. There is a bit of porting I still want to do, but the mighty mini-stroked Malossi is nearing completion. In light of the crankshaft being added to the build, I think I need to get a bigger carburetor, as my 21mm is a bit on the smallish side for my setup.
I'm thinking 28? 26? Suggestions?
Ol' Red
Broken...
Spreeio
1987 Spree
Broken...
Spreeio
1987 Spree
What speeds are you looking to get out of this crazy thing?
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
A minimum of 70. This is being built to go riding with full size motorcycles as well as other scooters. If I can push the 6.3 secondary gears... ??? I don't want to quote a number. Faster than safe. I want to be able run 55-60mph down the highway at partial throttle.
Ol' Red
Broken...
Spreeio
1987 Spree
Broken...
Spreeio
1987 Spree
I really hope you got some good brakes on this suckerSpreetard wrote:A minimum of 70. This is being built to go riding with full size motorcycles as well as other scooters. If I can push the 6.3 secondary gears... ??? I don't want to quote a number. Faster than safe. I want to be able run 55-60mph down the highway at partial throttle.
Lol minimum of 70, I'd want a diaper if I tried that on a spree
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
Ol' Red
Broken...
Spreeio
1987 Spree
Broken...
Spreeio
1987 Spree
- Trafficjamz
Yours is gonna go that fast too petrockPetrock's 1984 Spree wrote:
I really hope you got some good brakes on this sucker![]()
With 8.44:1 secondaries?
Oh boy
Oh boy
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
- Trafficjamz
Petrock's 1984 Spree wrote:With 8.44:1 secondaries?
Oh boy
60mph @9000 rpm with those gears !
If you can get your corsa to rev to 10000rpm 70mph could be closer than you think.
Hahah okay good! The thought of 70 is still way sketchy to me.
I'll leave porting decisions for a day a long way down the road. I'm perfectly fine with whatever guido did to make the corsa the way it is for now
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
[quote="Spreetard
Currently the bike is in a box, torn down to the smallest of components.
I have an 87 Elite 50 speedo for it.
[/quote]
The 87 elite speedo will fit a spree?
How fast do the 9:1 gears get you?
[/quote]
- Trafficjamz
matzke3 wrote:
The 87 elite speedo will fit a spree? Yes
How fast do the 9:1 gears get you? 50mph or so
SAWHEET. My sprees an 86 and I still have the speedo from the 87 elite donor. Ill spin the odometer to match and swap them. I ordered 9:1 gears and they havent arrived 50 MPH is around my goal.
matzke3 wrote:SAWHEET. My sprees an 86 and I still have the speedo from the 87 elite donor. Ill spin the odometer to match and swap them. I ordered 9:1 gears and they havent arrived 50 MPH is around my goal.
Sorry to burst the euphoric bubble but those gears will not fit in a Spree engine
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
-72cc Polini Corsa
-V8 Typhoon Exhaust
-21mm OKO & CT Mani
-ZX Trans 1k Contra
-8.44:1 Gears
-669x18x30 Belt
