So today I repainted the muffler trim piece with a red that matches more closely, took the side casing off to double check the kick starter the spring is set, polished up the side case cleaned up my work space, put the headlight Plastic back together, put the back plastics on so I could see how it looked and took the front wheel off and put it back on to make sure I did it right. Everything looked right when checked it and looked at the manual, the bearings all spin smoothly so I don't know why the wheel is not spinning well. Any ideas?
The last big update is that I started it, it took three tries but then fired up and stayed running, I only let it go about 30 seconds as its in a non vented basement, will move it up to the garage soon and let it run. During the thirty second run I tested the headlights whited worked, but the turn signals did not flash
What is the best way to ensure the oil pump is pumping? (I did prime it after cleaning the tank)
Jerome
