1999 honda elite
tony
1999 honda elite
Post by tony »
i have a kick start problem.kick it down wont come back up.is there a return spring broke.thank you tony
PolarIce
Re: 1999 honda elite
Post by PolarIce »
tony wrote:i have a kick start problem.kick it down wont come back up.is there a return spring broke.thank you tony
Yes!
Removed the kick start lever and take off the cover, it should be obvious.
1984 Honda NN50 Gyro
1986? Honda Aero 50
Served Onboard 94-97
It is probably just jammed up
The spring is pretty robust part....I have never seen a broken one.
wikked_spree57
Post by wikked_spree57 »
They can slip loose from the catch, but your most likely problem is the assembly needs a good greasing. If the cup gear goes dry the whole assembly will stick like none other.
1994 BMW 525i 5 speed BEAMER TIME
1983 Yamaha XC 180 - Bought barn fresh in mint condition and 254 miles. Best bike I ever owned :)
KINGÔäó
Post by KINGÔäó »
wikked_spree57 wrote:They can slip loose from the catch, but your most likely problem is the assembly needs a good greasing. If the cup gear goes dry the whole assembly will stick like none other.
grease the springs, starter idle, and the spindle. had this problem before, just needed to replace grease.
http://www.cheapcycleparts.com/model_ye ... blies/8595
grease 10,11, and 13 :geekdance:
Graphics Artist Vfx Car Collision
