Aero 50 motor in a spree?
Will a aero 50 motor fit in a spree? if so what mods need to be done?
Andrew
Andrew
2002 Yamaha bws 50
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
1969 Honda z 50 mini trail
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
Re: Aero 50 motor in a spree?
Yes, it is only slightly wider than the Spree engine. However you have to fabricate an engine mount.
ok Thanks bear, is the mount like the one you have to make for the dio motor swap?Bear45-70 wrote:Yes, it is only slightly wider than the Spree engine. However you have to fabricate an engine mount.
2002 Yamaha bws 50
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
Yes.ANDREW wrote:ok Thanks bear, is the mount like the one you have to make for the dio motor swap?Bear45-70 wrote:Yes, it is only slightly wider than the Spree engine. However you have to fabricate an engine mount.
The aero motor is very upgradeable right?
2002 Yamaha bws 50
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
Yes, the '83, '84, '86 and '87 more so than the '85 which has a not so upgradeable intake system.
Ok cool also do you know if there is a tuned pipe available for the aero 50?
2002 Yamaha bws 50
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
1984 Honda spree
1986 Honda spree
1986 Honda xr100r
1981 Yamaha yz 80
The Leo Vince SP3 is available for the af05 Aero 50 engines. I do not know of any pipe available for the '83-84 engines.ANDREW wrote:Ok cool also do you know if there is a tuned pipe available for the aero 50?
The engine mount will not be the same as the af16 if you were planning on using the same measurements but the skills needed will be the same.
- chevyguyjay
- fastplastic
theres not as many parts for the afo5 as the dio the afo5 has one maybe two bbks and a couple pipes the dio is way more upgradeable and can reach a lot higher speeds then the afo5 if thats what your looking for.....
There are more than two bores. I can pull three off the top of my head: Polini 47mm/65cc, CMR 46mm/63cc, Taz 44mm kit. I don't know if malossi still makes a kit but there are some sitting on a shelf that you see for sale every now and then.fastplastic wrote:theres not as many parts for the afo5 as the dio the afo5 has one maybe two bbks and a couple pipes the dio is way more upgradeable and can reach a lot higher speeds then the afo5 if thats what your looking for.....
- fastplastic
right but there getting harder to find now then before just saying the dio has way more parts thats all
- fastplastic
theres five of them there all not so easy to get though..... follow link to see them....eliteguy50 wrote:There are more than two bores. I can pull three off the top of my head: Polini 47mm/65cc, CMR 46mm/63cc, Taz 44mm kit. I don't know if malossi still makes a kit but there are some sitting on a shelf that you see for sale every now and then.fastplastic wrote:theres not as many parts for the afo5 as the dio the afo5 has one maybe two bbks and a couple pipes the dio is way more upgradeable and can reach a lot higher speeds then the afo5 if thats what your looking for.....
http://www.hondaspree.net/phpBB3/viewto ... =8&t=10804
